Far East Forum Serving Asia and surrounding Areas. Far East users, post event and club info here
Passing the 'shaken'
Old Aug 27, 2006 | 06:37 PM
outlawdsm's Avatar
How hard is it to pass the shaken with a highly modified car? I know here in the states to pass emissions, all i have to do is cough up some extra cash to get my car 'pass'. What also, what all do they check in the shaken? do they actually know what they are looking at? will i fail for an external wastegate vented to atmosphere, no EGR, no charcoal canister...ect. thanx guys.
Old Aug 29, 2006 | 02:23 AM
user 9348703's Avatar
depends........................
Alot of guys on here will say nope, but you got to have finesse.
I also passed with an external wastegate, no backseat, rollcage, no airpump, big single, no airfilter, feed wide fenders, wide fender pull in rear and thats about it hehe
Also if your car is old, beatup and a general POS!!! Then that hurts your odds alot too. I know some of the cars that are having trouble and I would say hummmm yeah...
Old Aug 29, 2006 | 11:32 AM
Valkyrie's Avatar
I don't think they're as **** as California emissions people, but you need to at least have the emissions actually hooked up (Ie, put your EGR back on), at least to the point where it would pass a smog test.
There IS a reason the companies that make these parts say they're for off-road use only, though...
Other tests include speedo accuracy, headlight allignment, etc...
Also, the shaken itself isn't what's expensive... fixing all the problems they find is what will kill you.
Old Aug 30, 2006 | 12:46 AM
NeilTII's Avatar
I just passed (Big pat on the back to myself!!!)
Heres a list of my mods:
Suspension, Turbo upgrade, 4" downpipe & exhaust, intercooler, injectors, ecu work, roll cage, 2.0 LSD, all guages, twin plate clutch, twin oilcoolers, aftermarket hood, alum radiator, no air pump, hood pins, battery relocated, and twin dump wastegate to atmosphere.
The removed air pump, wastegate, and hood pins are what gave my big problems. I made block off plates for the wastegate and had my title say "certified tested pumpless" on the bottom. Had to pay for the title change to say the no pump and switch from 4 seater to 2 seater.
JCI can be done like jt-imports said "with finesse.
Old Aug 30, 2006 | 06:14 PM
outlawdsm's Avatar
excellent info, exactly what i was looking for. thanx guys, your input is always valued by me.
JP's 93 fd
Sep 16, 2015 01:12 PM
