Sponsored by: CARiD
Tearing Down The Engine, Burning Oil.
Old Aug 24, 2006 | 06:44 PM
FFXLuc's Avatar
Ok I Have A 1983 RX7 1.1 Litre carburated engine and when I start driving I get engulfed in blue smoke I know it burning oil like crazy. So I want to start the project of tearing the top of the engine off and doing some replacing of the bearings. This is my first carburated engine so I understand the concept of what I'm doing but the process is a little different from a 3.1 DOHC So I'm in hopes that someone is willing to give me tips, websites, pictures, anything that would help meunderstand what I'm looking for and what to do with it please. Thank you. I've done bearing replacement before on cylinder heads, but a rotery engine works a bit different so I'm a bit out of my league here. Again I Appreciate any and as much help as I can get. I'm hoping to do this saturday and sunday if I get enough information and parts on time.
~Luc~
Old Aug 24, 2006 | 07:32 PM
Kentetsu's Avatar
You should probably be hanging out in the 1st gen section. For about $25.00 you can purchase a DVD video that will walk you through the entire rebuild process. Check over at www.atkinsrotary.com Before you rebuild, make sure that your oil level is not too high (this will cause excessive burning). Good luck.
Old Aug 25, 2006 | 02:59 PM
OneRotor's Avatar
RAWR
there are no heads. if you're burning a ton of oil, you're looking at a full rebuild, as the Oil Control Rings are worn out. How many miles on the motor?
Old Aug 26, 2006 | 02:25 PM
FFXLuc's Avatar
About 140K Miles On It. And Yes I Know It Doesn't Have Heads, I Was Just Making A Simularity.
Old Aug 26, 2006 | 04:29 PM
KeloidJonesJr.'s Avatar
strictly business
Disable teh OMP and premix ftw!
Old Aug 28, 2006 | 10:51 PM
trochoid's Avatar
Old Fart Young at Heart
And that will help his problem how? Your worthless posts are getting old, can't you find something more useful to do with your time?
Old Aug 29, 2006 | 10:19 AM
Kentetsu's Avatar
At least he is consistent...
Old Aug 29, 2006 | 10:57 PM
-xlr8planet-'s Avatar
I has an emblem
well... you can always try the Lucas Heavy Oil Stabilizer.
search here on the forum about it
you wont spend over 12 bucks so....
turbo-minivan
69
Feb 4, 2016 12:29 AM
elfking
Aug 19, 2015 09:48 PM
pzr2
Aug 15, 2015 08:29 PM
