Far East Forum Serving Asia and surrounding Areas. Far East users, post event and club info here
HelpIDLE JUMPING WITH FAN ON
Old Aug 18, 2006 | 02:02 AM
jef57's Avatar
I live in France , my fd has an european ecu(240 Hp/year 93), since i wan't 255 hp, I've bought japanese ecu (year 95).
But now when the fan run(high speed), idle jump 1200 to 2000-2500, When fan stop, idle come back 750-840 .
This idle fluctuationn is normal in japanese Rx7?
i' ve tried to adjust air bleed screw, but nothing happen.
Problem with water temp sensor? mines is Year 93, need I water temp sensor year 95 to resolve idle hunting.
Thanks for Help
Old Aug 18, 2006 | 08:33 AM
laujesse's Avatar
Thrashing your Roy score!
Veteran: Air Force
sounds like a trottle position sensor issue... Buy a PFC if you have the means or put your old ecu back in you are playing with fire and gasoline. The ecu you have could be modified. I doubt you will see a difference between the two. -Jesse
Old Aug 18, 2006 | 08:41 AM
jef57's Avatar
So, this fluctuation isn't normal
pfc is expensive
no other issue to solve my problem?
Can i adjust something or replace any parts ?
I haven't idle problem with stock ecu,
Thanks for your help
Old Aug 19, 2006 | 07:50 PM
laujesse's Avatar
Veteran: Air Force
PUT YOUR STOCK ECU BACK IN THEN.
A Japanese ecu is NOT going to give you ANY more power, ZERO. You are a long ways away from that man.
PUT YOUR STOCK ECU BACK IN.
You are going to blow your engine if you have a tuned ecu in your stock car.
PS: if puting your stock ecu in does not help, reread my first sentance on the last post.
Old Oct 6, 2006 | 04:06 PM
duffe's Avatar
Hi I had the same problem with my European FD.
I Had a japan ECU, and When the fan comes on, the idle go between 2000-3000rpm.
Now I use an USA ECU, and the engine runs fine
dona1326cosprings7
Oct 29, 2015 06:47 AM
izzolaw
Sep 28, 2015 06:03 AM
