What do you guys normally pay for paint jobs?
Mines got no rust, one dent and some small dings. What should I expect to pay for a factory (winning silver) paint job?
WOW stuff is inexpensive in Canada. I guess $1000 is OK if you are having someone you know paint it but for a quality job expect to pay from $2000 to $6000. $6000 is a full bare metal strip including seat removal rolling the carpet back and painting the door jambs and under hood and the rockers, part of the floor.
it depends on what you want. bodywork, paint, process, quality, labor, etc, etc.... it can range from a crappy quality maaco job for 300 bucks to quality body work and paint for over 8k.
Trending Topics
Jesus christ, who pays over $8k for a paint job, and why? A good quality job will be in the ballpark of $3.5k will pay for everything, jams, sunroof, engine bay, the works. Down to the frame will cost you a lot more, but anything above $5k is just overkill. For just the outside of the car, door jams, sunroof, look for around $2k-$3k. A cheaper job, with possibly cheaper materials can do you alright, but I wouldn't risk it.
Good materials (paint, clear, filler, sanding suppliers, primer/sealer, polish compounds) for a good paint job will run you $1K even with a shop discount on material. That's material mind you, then add labor: breakdown of trim, bodywork, painting, assembly and polishing. Your doing good to get under 3500 for a good quality paintjob.
The budget 500-1000 paint jobs will only last a few years. It all depends on what you are looking for.
You can get a show quality paint job for around 5 grand. The best thing you can do is utilize a friendship with a paint shop owner. That's what I did, scored a showcar quality paintjob for my FD for a *very* reasonable price
Perhaps a better question would be
"What can a non-professionaly do it yourselfer do to cut down the cost of a paint job"
I mean, most people who own rx's are typically of the mindset "If you want it done right, do it yourself". A few door dings should be easy to fill and sand, and with a decent D/A orbital polisher you should be able to sand most of the vehilce down to primer in a few days.
Another question -- What can a do it yourself "**** up"-- I mean, here's my thinking. You rx-7 is likely not your daily driver, so its not like you can't be without it for a month. If an amateur goes and does some "prepwork" is there any irreversable damage he can do (i'm not talking about cutting and welding fenders here, a door ding or a crease at the most), that would end up costing him MORE to take it to a body shop.
Basically, would it be true, that if you unavoidably need a paintjob, there is no harm in trying to do everything up to the actually spraying, yourself?
I would say you could remove the trim and scuff the paint. That's if all the spots that need to be body worked are marked and you stay away from them. I would go no further than that, as it takes a skilled hand and eye to be able block sand a car correctly. Its especially important on a dark car.
Guys. This is a rough estimate that I prepared. This is for an RX-7 with a perfect body. That means no repair time has been figured on any panel. Any dings and scratches would be extra. Use this as a reference point.
Sorry it didn't "copy" over very well. Let me know if you have any questions about it.
I've also included a .txt file of the same thing, but is easier to read.
NO. OP. DESCRIPTION QTY EXT. PRICE LABOR PAINT
1 FRONT BUMPER
2 REFN BUMPER COVER 3.0
3 ADD FOR CLEAR COAT 1.2
4 FRONT LAMPS
5* R&I RT LID 0.5*
6* R&I LT LID 0.5*
7 REFN LT LID 0.5
8 REFN RT LID 0.5
9 OVERLAP MINOR PANEL -0.2
10 O/H BUMPER ASSY 2.8
11 HOOD
12 REFN HOOD 3.5
13 OVERLAP MINOR PANEL -0.2
14 FENDER
08/18/2006 AT 02:24 PM JOB NUMBER:
24852
PRELIMINARY ESTIMATE
1993 MAZD RX-7 1.3L-TR 2D CPE INT:
15 REFN RT FENDER 2.5
16 OVERLAP MAJOR ADJ. PANEL -0.4
17 REFN LT FENDER 2.5
18 OVERLAP MAJOR ADJ. PANEL -0.4
19 R&I RT VENT ASSY GRILLE 0.5
20 R&I LT VENT ASSY GRILLE 0.5
21* REFN RT VENT ASSY GRILLE 0.5*
22* REFN LT VENT ASSY GRILLE 0.5*
23 ROOF
24 REFN ROOF PANEL 3.8
25 OVERLAP MAJOR ADJ. PANEL -0.4
26 DOOR
27 REFN RT OUTER PANEL 2.2
28 OVERLAP MAJOR ADJ. PANEL -0.4
29 REFN LT OUTER PANEL 2.2
30 OVERLAP MAJOR ADJ. PANEL -0.4
31 R&I RT BELT MOLDING 0.3
32 R&I LT BELT MOLDING 0.3
33 R&I RT MIRROR 0.5
34 R&I LT MIRROR 0.5
35* REFN RT MIRROR 0.5*
36* REFN LT MIRROR 0.5*
37 R&I RT HANDLE, OUTSIDE 0.4
38 R&I LT HANDLE, OUTSIDE 0.4
39 PILLARS, ROCKER & FLOOR
40 REFN RT UNISIDE ASSY S 2.5
41 OVERLAP MAJOR ADJ. PANEL -0.4
42 REFN LT UNISIDE ASSY S 2.5
43 OVERLAP MAJOR ADJ. PANEL -0.4
44 QUARTER PANEL
45 REFN RT QUARTER PANEL 2.7
46 OVERLAP MAJOR ADJ. PANEL -0.4
47 REFN LT QUARTER PANEL 2.7
48 OVERLAP MAJOR ADJ. PANEL -0.4
49 LIFT GATE
50 REFN LIFT GATE TO VIN 200251 2.0
51 OVERLAP MAJOR ADJ. PANEL -0.4
52* R&I SPOILER ASSY 0.8*
53 REFN SPOILER ASSY 1.2
54 OVERLAP MAJOR ADJ. PANEL -0.4
55 CLEAR COAT 2.5
56* R&I WIPER ARM 0.3*
57* R&I NOZZLE 0.5*
58 ELECTRICAL
59 R&I ANTENNA ASSY 1.2
60 REAR LAMPS
61 R&I RT COMBO LAMP ASSY 0.5
62 R&I LT COMBO LAMP ASSY 0.5
24852
63 O/H BUMPER ASSY 2.5
64 R&I RT BACKUP LAMP ASSY INCL.
65 R&I LT BACKUP LAMP ASSY INCL.
66 R&I RT SIDE MARKER LAMP 0.3
67 R&I LT SIDE MARKER LAMP 0.3
68* R&I LICENSE LAMP INCL.*
69 R&I HIGH MOUNT LAMP 0.5
70 REAR BUMPER
71 R&I R&I BUMPER ASSY INCL.
72 REFN BUMPER COVER UPPER 2.5
73 ADD FOR CLEAR COAT 1.0
74 REPL NAMEPLATE "MAZDA" 1 31.60 INCL.
75 REPL NAMEPLATE "RX-7" 1 58.95 INCL.
76 REPL EMBLEM LOGO 1 28.55 INCL.
77 R&I R&I BUMPER ASSY INCL.
78 INTERIOR TRIM
79 R&I RT DOOR TRIM PANEL 0.7
80 R&I LT DOOR TRIM PANEL 0.7
81 R&I LIFT GATE TRIM LOWER 0.5
82 R&I RT LIFT GATE TRIM SIDE 0.3
83 R&I LT LIFT GATE TRIM SIDE 0.3
84* R&I REAR TRIM 0.3*
85# RPR ROPE TAPE FRONT AND REAR GLASS 1.0
SUBTOTALS ==> 119.10 18.4 38.7
PARTS 119.10
BODY LABOR 18.4 HRS @$ 54.00/HR 993.60
PAINT LABOR 38.7 HRS @$ 54.00/HR 2089.80
PAINT SUPPLIES 42.7 HRS @$ 32.00/HR 1366.40
SUBTOTAL $ 4568.90
SALES TAX $ 1485.50 @ 7.5000% 111.41
GRAND TOTAL $ 4680.31
ADJUSTMENTS:
DEDUCTIBLE 0.00
CUSTOMER PAY $ 0.00
INSURANCE PAY $ 4680.31
1 FRONT BUMPER
4 FRONT LAMPS
5* R&I RT LID 0.5*
6* R&I LT LID 0.5*
7 REFN LT LID 0.5
8 REFN RT LID 0.5
11 HOOD
12 REFN HOOD 3.5
14 FENDER
24852
23 ROOF
26 DOOR
44 QUARTER PANEL
49 LIFT GATE
55 CLEAR COAT 2.5
57* R&I NOZZLE 0.5*
58 ELECTRICAL
60 REAR LAMPS
24852
70 REAR BUMPER
78 INTERIOR TRIM
PARTS 119.10
SUBTOTAL $ 4568.90
ADJUSTMENTS:
DEDUCTIBLE 0.00
CUSTOMER PAY $ 0.00
I'd really like to know where some of you guys are coming up with these numbers, $800 for a badass paintjob? 1 gal primer = $270, 1 gal paint =$300, reducer + $70, Clear $200. Materials only $840.
Realize that the body work and the priming you can easily do yourself. You'll have probably sprayed 8 coats of primer, and sanded off 6 while doing the body work. Guide coat and block everythign down and any imperfections will be sanded out. Then let a pro in a booth lay down the sealer, base and clear. You'll cut out 70% of the cost & have a professional job
Ok -- so, i don't understand all the abreviated codes.
Is this for a full, colour change quality repaint? Door sills, rear hatch area excluding the engine bay, or is this for a respray?
I understand body labour, and pain labour, but "paint suplies @ 42.7hrs" what is that? Why would your supplies be billed at an hourly rate rather than jsut cost?
Originally Posted by TitaniumTT
Did everything but the body in my garage. Properly cleaned vented and filtered and you're good to go.
I'll probably be spending like a grand for the paintjob. I learned how to do the whole thing myself in this auto collision class I took in high school. Its just a daily driver NA :/
REFN = Refinish
REPL = Replace
R & I = Remove and install
RPR = Repair
The estimate that I posted is for a completed exterior paint job only.
Materials are often figured at an hourly rate. The hourly rate comes from the amount of book time figured to refinish each panel. This isn't the most accurate way to figure the cost of materials, but it is standardized. This method helps the customer more than anyone. Example: The fender pays 2.5 hours to refinish. That means there is 2.5 hours of labor charged at $56.00 / hour which comes to $140.00. Then you take the 2.5 hours and multiply it by the material rate which is $32.00 / hour which comes to $80.00. Therefore, if a painter makes a mistake and needs to use more materials than normal, the customer will not be charged for it. This method of charging for materials includes all materials used such as: sand paper, tape, masking paper, primer, sealer, base, clear, reducer, hardener.... It's much easier to charge this way instead of keeping a list of everything used on the car.
I know it's a little confusing, but I hope it helps.
Originally Posted by Rufio
i got a bunch of dings pulled out, plus the whole car resprayed for $800 and its a badass job
I didn't even know people got door jambs done...I don't even care about that ****
Wow, i never realized how much the cost of a paint job was the prep stuff.
I wouldn't cost that much at all to actually get the car "Painted" if that's what was involved, if a vehicled showed up on a tow truck, sanded, taped, and pulled apart the actually painting isn't that costly, it's the remove and install's that kill you.
