99 front lip
Old Feb 24, 2002 | 11:20 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
99 front lip
After seeing pics of the 99 front lip on FD's and seeing the small overhang on the side it got me wondering why no one has just trimmed a little bit off of each side in the middle where they join together to get them to fit correctly. Has anyone done this?
Old Feb 25, 2002 | 12:23 AM
rx7even's Avatar
Well it's not a solid piece as it appears to be, so if you were to trip the ends up to make it flush, you'd actually end up with a hole there instead. In the front where it doesnt fit perfectly, the same thing would happen. I thought about heating mine up with a heat gun until it started to get soft and melt a little, and then pull it back till it was flush with the bumper, but that would discolor the plastic some, so I wouldnt attempt it unless I planned on painting the spoiler. Here's 3 pictures that might help some more.
Old Feb 25, 2002 | 12:32 AM
DeNguyen's Avatar
the only way to do it is cut it up, glue it back together(so it fits perfect), make a mold, and sell tons of fiberglass copies for dirt cheap...
i dont see anyway to make it fit perfectly. and besides the little gap only bothered me for a couple days.
Old Mar 11, 2002 | 04:16 AM
duboisr's Avatar
garfinkle pulled the corners of his bumper out and clamped it then drilled and bolted the corners and inside ends it looks even all around no gaps
sYnth.
Aug 19, 2015 06:27 PM
MILOS7
Aug 15, 2015 09:40 PM
