Does anyone make stiff steering rack bushing?
Old Aug 16, 2006 | 01:23 AM
twistedriver's Avatar
Finally I have LSD
Does anyone make stiff steering rack bushing for 2nd gen rx7s? The stock bushing is kind of soft. I seen them for subies and hondas before i just can't find any for FCs. What are some other ways of improving steering feel other then bars? THanks!!
Old Aug 16, 2006 | 08:49 AM
DamonB's Avatar
Increase the caster.
Old Aug 16, 2006 | 07:05 PM
Black91n/a's Avatar
The stiffer bushings are useful in the other cars because theirs are overly soft and the rack actually will move back and forth. Ours are fairly thin, and when I had my rack out last year, the bushings were in good condition. I don't think the rack actually moves around much at all.
Old Aug 17, 2006 | 12:28 PM
240sx's Avatar
getting rid of p/s increases steering feel
Old Aug 18, 2006 | 01:26 AM
Finally I have LSD
First of all thanks for the reply. I already have a manual rack, but when i drove a rx8 that totally blew my mind. The steering feel and precsion was amazing. I understand that the new car structur is much stiffer but i feel a better steering feel could be possible with the fc chassie. Currenty i have new tie rod ends, poly bushing, gab shocks in the front and a ebay strut bar (f and r). I might try to add a bottom front chassie bar and a better top strut bar. What else can i do to improve steering feel? HOw much caster should i dial in?? Thanks!
Old Aug 18, 2006 | 02:02 AM
RETed's Avatar
Doesn't the RX-8 use "electronically assisted" steering?
How about stiffer sidewall / lower aspect ratio tires?
-Ted
Old Aug 18, 2006 | 10:32 AM
wanklin's Avatar
Rob
-Ted
Yes it does and it is unfortunately prone to failure. I sell aftermarket steering rack bushings, imported from Australia, for the FD, I'll check and see what I can get for the FC.
Rob
Old Aug 18, 2006 | 11:51 PM
--MAstermind--'s Avatar
any info on this?
Old Aug 19, 2006 | 12:25 AM
wanklin's Avatar
Rob
I'm looking into it ;o)
autoxer
21
May 22, 2019 04:07 PM
astrum
24
Nov 15, 2017 08:44 AM
NCross
Aug 29, 2015 01:55 PM
GrossPolluter
Aug 15, 2015 10:32 PM
