special tool
Old Aug 9, 2006 | 02:24 AM
special tool
Does anyone knew where can purchase special tool for take off 20b eccentric shaft?? Thanks
Old Aug 9, 2006 | 04:09 AM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
your best bet is to make one. I had a guy in the states build me one, although I dont think he does them anymore
Old Aug 9, 2006 | 09:50 AM
mcfly's Avatar
can someone post a picture so it can be replicated
Old Aug 9, 2006 | 10:19 AM
calculon's Avatar
On flats
i asked this before. . .there is a thread somewhere in the 20B subforum loaded with pics and specs
search for something to the tune of
"eccentric shaft puller"
or something along those lines.
-ryan
Old Aug 9, 2006 | 10:22 AM
calculon's Avatar
On flats
Here it is
Sorry for being lazy earlier. . .that's all the info i've got on it. . .i've got the tool too. I'll send it to you to use for a deposit, but dunno if you wanna go that route.
-ryan
Old Aug 10, 2006 | 12:27 PM
rotoryfreak's Avatar
Folow this link .. Link
Look at the pics ... i did the same thing very easy ...
Save some money not worth buying the tool ..
Old Aug 10, 2006 | 07:56 PM
t-von's Avatar
Rotor Head Extreme
A puller isn't necessary. Get yourself a hammer, a pry bar, and a small piece of wood. Place the piece of wood on the plate to rest the pry bar underneath it. Screw on the big front e-shaft pully boss nut. Putting the nut back on will protect the treads. While prying up the front rotor lobe with the pry bar, tap the top of the e-shaft with the hammer. The e-shaft will easily separate. That's how I did mine.
There was a web page around here showing how to do it.
Edit: I found the pic from that web page.
[http://www.rotaryheads.com/2nd-gen-r...teardown17.jpg
Old Aug 10, 2006 | 10:30 PM
Hi everyone,
I m really thanks to teachermechanic to share with us. So we can make our own.https://www.rx7club.com/showthread.p...ighlight=puller
Old Aug 10, 2006 | 10:35 PM
Sorry its doesnt worked. Try this https://www.rx7club.com/showthread.p...ghlight=puller
Old Aug 17, 2006 | 07:41 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
if you do it with the prybar, just make sure it doesn't slip off and scratch the shaft. it'll make you cry.
Old Aug 18, 2006 | 06:34 PM
mad20b's Avatar
I have a few here I can sell. Have supplied a few members on here. They are all brass bushed to avoid damage to the shaft.
Old Aug 18, 2006 | 08:09 PM
RX-Heven's Avatar
I'll blow it up real good
You have a pm.
Old Aug 20, 2006 | 02:47 AM
How much $$ for it?
Coochas
44
Nov 5, 2019 11:08 PM
LongDuck
Oct 7, 2015 08:12 PM
jdmbrendan
Oct 1, 2015 01:29 AM
manoflego
19
Sep 30, 2015 05:19 AM
