Haltech haltech software wont connect to E6K
Old Aug 8, 2006 | 10:37 PM
mtek7's Avatar
downloaded haltech E6K software from haltech.com running on windows XP,
it gives the error that can't open com 1 , i'm using usb to serial cable , no matter what i do it just says reconnect haltech, E6K software is not comparable with Windows XP ? your input is appreciated .
Rob
Old Aug 8, 2006 | 10:44 PM
davedge's Avatar
WindowsXP is not compatable with ANY DOS software...
You will neep Windows98 or previous in order to use the E6K DOS based software...
Old Aug 8, 2006 | 10:46 PM
nik's Avatar
nik
E6K software is DOS only. The problem is winXP runs dos programs through a sort of emulator and system resources like com ports are usually not available for these programs to access.
Easiest thing to do is make a boot diskette(or CD) with DOS on it. However, there may be some funky software out there that lets dos programs access com ports.
Old Aug 9, 2006 | 08:49 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
You need to read this post.
http://p210.ezboard.com/fhaltechdisc...cID=1575.topic
It goes into explaining why haltech software wont connect, and a few other goodies.
Old Aug 10, 2006 | 11:22 AM
mtek7's Avatar
still dont work
i downloaded the compaq version and same thing no connection , WTF!
Thanks
Rob.
Old Aug 10, 2006 | 11:28 AM
davedge's Avatar
^^^^^^^^^^^^^Did you take the time to read this?^^^^^^^^^^^^^^
Old Aug 10, 2006 | 01:00 PM
mtek7's Avatar
yes i did
i will be downloading mvm or vmware and i will give it a try , hopefully that will solve my issue , thanks for your valuable input everybody .
Rob.
Captain Hook
13
Oct 4, 2015 06:35 PM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
