testing for blown coilovers?
Old Aug 2, 2006 | 03:51 AM
turbo-polak's Avatar
how do you test to see if a set of coilovers is blown? currently they are not in the car, so i cant really do that bounce test...
but what i did was loosened the collars all the way down, so that the spring is loose, and compressed the shock, and waited to see if it would come back up on its own... is this a good way to test them?
cheers,Dan.
Old Aug 2, 2006 | 04:46 AM
Rx Seven's Avatar
Can You Wankel?
I have tested some this way if they don't come back up or move really really slowly there blown.
Old Aug 2, 2006 | 02:40 PM
Black91n/a's Avatar
Not really, it depends on the valving and gas pressure. Monotubes should extend fully right away, whereas twin tubes might not do it at all, even when they're perfectly alright.
Old Aug 2, 2006 | 11:17 PM
Trout2's Avatar
Find someone with a shock dyno to test them.
Old Aug 3, 2006 | 08:28 PM
sereneseven's Avatar
All gas pressurized shocks should push the shaft all the way out of the body ...with this said all that you are testing is that the shock still has some pressure in it however pressure is only one peice of the puzzle the part you are interested in is the shim stack which can only be tested on a dyno...soo if your really concerned and you have spent over say $ 500 on them send them out to have them dynoed if not simply buy tokicko and replace every few years.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
