to all you high hp & single turbo guys
Old Aug 1, 2006 | 06:00 PM
darkphantom's Avatar
The king of the highway!
any of you have problems with traction?
and does the car scare you everytime you drive it?
last night i had a run in with a 350Z TT and had a bad launch. the tires kept spinning bad! (brand new tires too) launched around 6K
Old Aug 1, 2006 | 06:42 PM
Nihilanthic's Avatar
moon ******
Um.... put on bigger, stickier tires? Get DRs?
Cant FDs handle 265s out back with stock fenders, and proper offset/spacers? Go get some!
And what tires are you using now?
Old Aug 1, 2006 | 07:48 PM
255's All Around
Old Aug 1, 2006 | 08:27 PM
showoff's Avatar
Originally Posted by darkphantom
255's All Around
your best bet is to get some dr's for everyday and et streets for the track even on my low boost setting(380rwhp) the car likes to slide around until about 3rd gear
-dj
Old Aug 1, 2006 | 08:36 PM
the_glass_man's Avatar
Will u do me a kindness?
You can get up to 315's without fender flares if you want to be creative. Otherwise 285's are easily doable.
Old Aug 1, 2006 | 08:56 PM
matty's Avatar
keep us posted on how much rwhp your car makes please.
Old Aug 1, 2006 | 09:44 PM
IM STILL BREAKING THE MOTOR IN. im expecting 500hp but i know for sure my stock fuel lines arent going to support it!
i get it dynoed & tunned this saturday so ill let you guys know how it does!
a showoff what rpm you launch @
Old Aug 1, 2006 | 09:56 PM
showoff's Avatar
well i use 2 launch at 4.5 5grand and slip it out with my street disk.. but with my newly installed 6puck and extreme pressure plate it doesnt slip much so i stick to dropping it softly around 4grand.... regardless of launch on street tires if you dont feather it alot your gonna spin all of first and most of 2nd.. the next thing i buy for my car will be dr's or et streets
-dj
Old Aug 2, 2006 | 03:17 PM
SlingShotRX7's Avatar
You won't have to worry about tire spin in a month or two.
Why??
Because, your single turbo set up is gonna eat your clutch.
and you won't spin tires as much.
Don't ask how I know.. = )
Old Aug 2, 2006 | 09:26 PM
SAGE's Avatar
i make 340rwhp and launch at 7.8 -8k on 26/10.5/16 et streets never had a problem with it. Almost every time i dead hook it.
Old Aug 2, 2006 | 10:10 PM
Fd3BOOST's Avatar
Recovering Milkaholic
Run them from a roll and you'll have better luck.
I have 265's on the back and it will cut loose pretty much through 3rd. It does not scare you if you just keep the wheel straight. If it starts to go to far sideways then let off the gas.
Old Aug 2, 2006 | 10:14 PM
iceman4357's Avatar
-dj
Thats about how mine is now. Im getting my halfbridge back in about a month with my T78. I should make over 500whp im hoping. Then with the water injection i can run higher boost, and get close to 600hp. I just cant wait to hear the BRAP BRAP!
Old Aug 3, 2006 | 01:39 AM
/\ at first it was wierd. but after i installed the resonator on the midpipe it isnt that loud as you think. Youll get a lot of eye poping because of your idle but im kool with it.
BTW iceman you did your halfbridge project before i did. Whats the holdup?
Old Aug 3, 2006 | 12:58 PM
iceman4357's Avatar
...insurance company is the damn holdup. My car has been gone for 8 months now. I have been battling them for the whole time. They dont want to pay for ****. I have everything covered by them except my single turbo. I had it rebuilt 2 weeks before a lady hit me, now the turbo squirts oil and the insurance company doesnt think its "accident related" so im going to just cover the turbo myself. I have to call Jason at the rx7 store to see if the turbo is done yet. I just need the turbo and a tune and its done!!
Old Aug 4, 2006 | 08:47 PM
well i just came from tunning the car and because we didnt hook up the boost controller we had to run on what the wastegate spring was on which was 9-10psi.
started out with 328.0HP @ 9lbs
ended with 384.3hp @9lbs
wanted to up the boost but were going to hook up the boost controller tomorrow!
a iceman keep me updated with the car
Old Aug 4, 2006 | 08:51 PM
showoff's Avatar
real impressive numbers at 9pounds keep every1 updated
Old Aug 5, 2006 | 10:24 AM
Indian's Avatar
It wasn't me!!
definetly agree!! Great numbers.
Old Aug 8, 2006 | 12:29 AM
bobybeach's Avatar
your stock fuel lines will do fine, I have a customer/friend who has made 513whp with stock fuel lines and one 044 pump.
Old Aug 8, 2006 | 01:51 AM
/\ thanks for the advise.
yesterday i ran this blue srt4 neon that had around 435hp
http://www.southfloridaracing.com/
and the funny thing is that i have around 50hp less and i beat him by 4cars in 4th gear. dunno how but it happened.
a little tip (some of you might know) but starting in 2nd gear really helps on a roll. usually in 3rd it takes a second for it to spool but when starting in 2nd your around 5-6000rpm & as soon as you hit the gas, bam instant spool. the only downside is you have to shift eariler (within 2-3seconds)
Old Aug 8, 2006 | 07:04 AM
matty's Avatar
i start at 3500-4k. primary turbo spools instantly andwithin a second u are into secodnary. of course this with the stock twins.
Old Aug 8, 2006 | 12:06 PM
nocomply24's Avatar
STOCK TIWNS ROCK! where the lag at?? i have no idea! cause i dont got it!
Old Aug 9, 2006 | 04:53 PM
Sequential Or Non Sequential?
