Won't start when hot
Old Jul 29, 2006 | 10:39 PM
coyne002's Avatar
Newbie
87 Turbo II starts well when cold. Mechanic says it has a "good used turbo" with no leaks. It has 95,000 miles on it.
It takes vigorous pumping of the accelerator and 4-5 tries to start it when it is hot. If the idle is kept up a minute or two, it runs fine after that. It has some pep, but doesn't seem a quick as it should be.
Compression testing was normal, and it doesn't use much oil. The catalytic converter was clogged, but isn't now.
Any things I can tell the mechanic about these problems? Any good Rx7 places in the Minneapolis/St. Paul area? Thanks
Old Aug 7, 2006 | 10:50 AM
thinkimagetone's Avatar
i got one hehe
haha i have the same problem it wont start when hot. and it sucks.
Old Aug 7, 2006 | 08:28 PM
EricRyan's Avatar
Autocrossed. I got CONED!
When I first got my FC, it wouldn't start after running it for a few minutes.
Turns out the previous owner had the trailing plugs hooked up in the leading and vice versa. It's a long shot, but check your spark plugs for the correct order, as well as any kind of obvious signs of detonation damage to the plugs.
Old Aug 7, 2006 | 09:31 PM
hondahater's Avatar
spending too much money..
stuck injectors and low compression are usually the cause of your hot start symptoms.
Old Aug 8, 2006 | 04:59 PM
i got one hehe
yeah well compression may have been my problem. i went out to remove the plugs and the fronts were tight. but the rears werent tight as they should be. the bottom rear was hand tight. so i tightened them back up and i havnt drove it yet i got to get jumped off. but i will let u guys know how it goes.
Old Aug 15, 2006 | 10:20 AM
signofinfinity's Avatar
Coyote
compression.....
i had a stuck side seal and it never fired up hot.
loose plugs can be a problem, but if you are loosing that little comp through the plugs and it wont start i would consider a compression test and see were you are.
cheers
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
Im faster
Aug 19, 2015 02:57 PM
befarrer
Aug 14, 2015 04:18 PM
