Microtech Very strange Spark Problem
Old Jul 27, 2006 | 11:50 PM
chris_stampe's Avatar
I have been running my ltx8 for a while now, but after my rebuild I have started having ignition issues with it.
It worked fine for about 10 mins after my first startup, but then the car started to idle funny and studder, so I checked and I was only getting spark on L1 and T2!
T1 and L2 have no spark, but the coils are good. I pulled my ignition harness and checked it for shorts.....none.
The MT shows no errors.
There is still no spark in test mode.
If I hook say the yellow wire (L1) up to the coil for T1 and check T1 spark in test mode, it sparks.
This has left me with two possibilities: The MT is busted, or could it be a grounding issue?
Anybody have any idea what could be wrong with this bastard?
Old Jul 28, 2006 | 01:52 PM
well ****, today all of the ignition outputs failed, so I pulled the mt out and it was blistering hot. It looks like something shorted out in the ignition part of the ecu. what could have caused this???
Old Jul 28, 2006 | 03:50 PM
I pulled the ecu apart and it looks like the ignition part of the circut is completely fried....now what? Send it to mt or what?
Old Jul 29, 2006 | 09:44 PM
No you probably dont have to ship it back!
mine had the same problem and it was only 2 transistors that got toasted and 2 little printed circuit melted
any GOOD electronic/cybernetic shop could probably help here
I got mine fixed at my friend cybernetics shop! cheap repair costs too!
l-p
Old Jul 30, 2006 | 01:11 PM
So what exactly caused the short? I cant find anything wrong with my harness wiring.
Also this is a picture of what mine looks like. Does anyone have a picture of a good circuit board? This one is probably toasted too much to have someone do a repair. If I had a picture tho, I was told it might be possible to repair it.
Old Jul 30, 2006 | 01:15 PM
Here's the front of it, with the heat sink removed.
Old Aug 8, 2006 | 07:24 PM
TonyTurboII's Avatar
Glock Lover
Holy ****, lol.
Old Aug 8, 2006 | 11:38 PM
1sgen's Avatar
583 rwhp 1st gen
what caused the problem to start with?
bad electronics or something you did?
Old Aug 9, 2006 | 02:01 AM
I dont know. My wiring had no shorts in it, and the coils had the proper resistence. I guess it must have been an internal problem. I resoldered all the components and ran new wires where needed and got it to work for a couple minutes, but it got hot again (with different coils and wiring this time). So I ordered new components from an electronics supply store and I will put those in and try.
Old Aug 23, 2006 | 10:37 PM
Glock Lover
Youre fixing it yourself?
GOOD LUCK.
Looks like too much is wasted to even try.
did you contact Microtech?
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
Microtech
Nov 21, 2015 10:20 AM
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
