Problem with my KONI's? (with Pics and details) Help is appreciated!
Old Jul 26, 2006 | 10:35 PM
Stephen C's Avatar
shopping for another RX-7
Hey, the FD that I bought has KONI adjustable-dampeners on it and the front tires (Bridgestone Potenza S-03's) seem to be touching the inside of the front-fenders on hard turns, curling the metal outwards (as can be seen in the pics).
What is strange is the front driver's-side fender is lowest to the tire (when all 4 dampeneres are adjusted to the same level). I also observed when trying to adjust the dampeners with the KONI-**** that the front driver's-side rod leaked a bit of oil when I began the adjustments (the small oil-leak was brief and ceased after several seconds); the oil was transparent, odorous, and of thin consistency (there was no oil-leak from the other 3 rods).
My question is why is the front driver's-side lower than the others? (the car has a clean title)
Is the small oil-leak from the front driver's-side dampener abnormal?
How can I fix the front dampeners so that they are of equal height and no longer touch the inside of the fenders? (without down-sizing my front tires)
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
Th0m4s
Feb 26, 2019 02:04 AM
