Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D Serial port vs USB adapter
Old Jul 25, 2006 | 07:17 PM
pilot's Avatar
I tuned my ECU from the first time with just a desktop PC next to my car as I donīt own a notebook. When I started thinking on buying one, I faced the fact that most of the modern units donīt have a serial port. Then I started finding out about USB-serial adapters.
Havenīt bought my notebook yet, I already bought and adapter and tested it with my desktop computer (the brand is "Noga").
Using Wolfīs 4.49 PC software, it takes 9 seconds to load the maps from the ECU to the PC using a serial port (serial port setup at 9600bps on Windows device manager).
Using the same soft and now using the USB-serial adapter, it took 56 seconds to load the same thing (this PC has USB 1.0). Then I changed to a newer PC with USB 2.0 and the time dropped to 34s (in this newer PC, the serial connection takes the same time than in the older one: 9 s).
When using the adapter I tried changing the transfer speed at both the Windows device manager and Wolfīs soft with no difference in the results.
Did anybody make similar tests? I asked Steve from Wolf about this and he told me that the adapter they sell has similar transfer speed to a direct serial port connection.
What do you think? another option would be a PCMCIA (ot whatever itīs spelled) card. What do you think of this?
Old Jul 25, 2006 | 08:28 PM
nyt's Avatar
nyt
some adapters are just awful, some are not. I don't have much experience with them, but I have seen transfer times equal to serial ports with them before.
Old Jul 27, 2006 | 12:07 AM
pilot's Avatar
If anyone has experience with these adapters with Wolf ECUs, it would be great to make a database of the brands and models.
Old Jul 27, 2006 | 12:09 AM
nyt's Avatar
nyt
btw, wolf uses 38400 as a serial transfer speed unless set otherwise, not 9600
Old Jul 28, 2006 | 10:48 AM
pilot's Avatar
I know that 38400 is its default speed, but windows setups serial ports at 9600 as default. I tested it at both 9600 and at 38400 using serial port and USB adapter without changing the results (serial port took 9 seconds at either speed and adapter took 56 and 34 respectively).
Joe's_7
Sep 8, 2015 04:44 PM
