how much boost can i run
Old Jul 25, 2006 | 07:02 PM
london's Avatar
I have a HKS GT Wastegate 60mm and i am running a 8.5 - 14.2 psi spring ,whats the most boost i can run comfortably with this spring installed.
Old Jul 26, 2006 | 09:03 AM
dubulup's Avatar
development
I don't know what you mean by a 8.5-14.2 psi spring. The springs I know of don't have a variable constant...but I don't know if the GT WG has this option.
if the WG spring is 8.5psi, then the lowest boost you can run is 8.5psi
if the WG spring is 14.2psi, then the lowest boost you can run is 14.2psi
how high you can go depends on your boost controller.
Old Jul 26, 2006 | 12:26 PM
Zero R's Avatar
Just in time to die
Not entirely true, depending on manfold design and a few other details if you run say a 10lb spring I wouldn't run more than 15lbs. You will start to get oscillations with the WG and hence the power delivery. Try to stay within a few psi of spring pressure for a good solid curve.
Queppa
Nov 18, 2024 03:47 AM
smikels
Aug 18, 2015 01:26 PM
Wolf_
Aug 11, 2015 04:23 PM
