Power FC Injector Map Value Won't Allow > 1.5??
Old Jul 25, 2006 | 11:07 AM
xblazinlv's Avatar
Ferrari Red Hotness
Last night when tuning my car on the dyno, I noticed that using the DATALOGIT, the highest number we could set an injector map cell to was 1.5, which would then be rounded to 1.496
Is there a reason for this? I've seen plenty of maps with values set higher than this, so I was a bit confused. Thanks
Old Jul 25, 2006 | 03:00 PM
cewrx7r1's Avatar
Eye In The Sky
That 1.49 or 149% max value limitation only applies to the COMMANDER.
With the DATALOGIT, you can use the RECALC function to take the fuel correction values and apply them to the base fuel map. This resets the correction map back to all 1s which is 100%. And it also ***** up the O2 feedback for idle and cruise; there is a way around this, it has been posted here or buy my tuning notes which tell this and more.
Old Jul 25, 2006 | 03:28 PM
xblazinlv's Avatar
Ferrari Red Hotness
Gotcha, just wanted to check because I was using a datalogit to change the values, but it would automatically reset them to 1.496 as soon as I entered a higher number. I'll search for your re-calc section in the tuning notes. THanks
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
eddierotary
Aug 16, 2015 04:12 PM
