EFI Harness ground....
Old Jul 24, 2006 | 07:39 PM
Archangels's Avatar
- Make Haste -
Question EFI Harness ground....
Wondering if anyone has pics or information about this ground, i'm grounding it tommorow and would like a pic atleast to know that i'm grounding the proper thing....
anymore information/hints are greatly appreciated....
Old Jul 24, 2006 | 07:41 PM
Sideways7's Avatar
Check out the grounding faq in the archives. Other than that, I can't help you cause my car's in pieces.
Old Jul 24, 2006 | 07:59 PM
Digi7ech's Avatar
I break Diff mounts
The EFI harness ground on a FC TII?
If so then It's a ring terminal under the UIM.
The rack which holds the end cap of the TB has 2 12mm screws to the engine block. I think it goes to the one closest to the firewall but it shouldn;t matter as long as you make a clean contact surface(sand it to get bare metal)
As some over kill.
You could string an extra wire from that ring terminal spot to the firewall as well.
Then reground your boost sensor on the pass fender.
Then get a beefy cable for a negative to fender/strut ground.
Good luck and be careful with some of the wires under there. Some are brittle.
Actually here's an old pic I have.
You can kind of see it on the bottom left of the block.
Old Jul 25, 2006 | 03:05 AM
Archangels's Avatar
- Make Haste -
ahh, it's near all of your fancy blue hoses and such?...
it's the one that looks brown/black, correct?...
so i ground that to the firewall as you say, or to the strut-tower and i should be good?...
Old Jul 25, 2006 | 02:29 PM
Digi7ech's Avatar
I break Diff mounts
Well. It's suppose to be at that bolt but chaining it to a firewall or strut also helps keep the grounding good.
Old Jul 25, 2006 | 02:40 PM
Archangels's Avatar
- Make Haste -
but i can run a ground-strap from that specific bolt to the strut-tower, correct?...
this bolt?...
Old Jul 25, 2006 | 02:47 PM
Digi7ech's Avatar
I break Diff mounts
yup.
Any bolt really but linking ground wires directly helps make sure they are all on the same level instead of having one which the resistance may differ.
Old Jul 25, 2006 | 02:53 PM
Archangels's Avatar
- Make Haste -
Originally Posted by Digi7ech
yup.
could you explain to me what you mean by l inking ground wires?...
i'm about to run out to the garage to start work on this....
Old Jul 26, 2006 | 03:46 AM
Archangels's Avatar
- Make Haste -
i just realized i already grounded this, i grounded the front bolt on the front rotor housing to the strut tower, and didnt touch the rear rotor housing....
would it be in my best interest to ground the rear-rotor housing aswell?...
and if so, should i run a very short ground-strap from the front rotor housing, to the rear?, and aswell having the front to the strut tower and rear to the firewall, just for good measure?...
also, is there anything else under the UIM that i should ground?, i was told there's something near the injectors that i should ground, to get to the one's on the rotor housings, i didnt have to move anything, i have a FMIC though....
Old Jul 26, 2006 | 05:59 AM
AlexG13B's Avatar
brap brap brap
Can somebody post a pic of the ground to strut tower? I don't recall seeing one on my car
Old Jul 26, 2006 | 12:32 PM
Archangels's Avatar
- Make Haste -
are you talking about grounding to strut tower?, like say your alternator to strut tower?...
i just used the bolts ontop of the strut tower, the bolts that connect to your strut assembly....
Old Jul 26, 2006 | 01:34 PM
Digi7ech's Avatar
I break Diff mounts
The whole Idea of regrounding everything is to try and keep the reistance as close to 0 ohms and keeping continuity between the part and ECU.
The stock harnesses usually end up getting cruddy and start to develop reisistance or maybe the wire breaks all together causing an open circuit.
The entire metal chassic of the car is one big terminal for the ground. Anything which isn't conductive has a possibilty of adding resistance. A rubber gasket between body panels, The RTV between metal pieces,etc...
Linking ground wires acts like a bridge to help step over these possible barriers.
That way if the original electrical path is cut off or getting bad it has another way to go to get to the final destination. It's a redundency thing.
If you wanted to do it the perfect way you would test places before adding a ground wire.
Like using an ohmmeter to see of you get resistance between the EFI ring terminal and the ECU plug, or the battery,or the firewall.
If one doesn't go well or even connect then Add a ground wire to it.
Old Jul 26, 2006 | 04:54 PM
Archangels's Avatar
- Make Haste -
i've been testing every connection with an ohm meter, and so far i've done alright, to confirm i'm going to make a ground from the rear-rotor housing to the firewall, and from the front rotor housing to the rear, to link the 2 together, they are somewhat easily accessable, so it's worth a shot....
i'm going to try and sand down some of the connections i've made to ensure that they are clean aswell....
i hope this works....
Old Jul 26, 2006 | 05:18 PM
Carzy Driver's Avatar
Law Breaker
use some dielectric grease on those connections just to help further protect them from corrosion.
scissorhands
Sep 16, 2015 01:25 PM
