Help! Car posessed by 'Satan'
Old Jul 24, 2006 | 03:26 PM
Ril_Silver's Avatar
Well I got the engine to work out and all that, now when I remove the key from the ignition the car remains on and running. If I pull back on the pedel it will die out so i'm not sure if I have a nasty eletric gremlin playing with my sytem or if I have an overtight throttle cable. Any ideas on how this could have gone down? Oh and the rest of the eletrical system remains in operation as well.
Old Jul 24, 2006 | 03:32 PM
My5ABaby's Avatar
Rotaries confuse me
Your car staying on doesn't have anything to do with your throttle cable.
My guess, faulty ignition switch.
or...
Originally Posted by HAILERS
IF the alternator wires are crossed, the power will backfeed into the igniton circuit and the removal of the key will have no effect.
Next time you turn the car off and remove the key, and the engine keeps running, go to the alternator and remove the small two wire plug and see if that has an effect.
Old Jul 24, 2006 | 03:44 PM
classicauto's Avatar
Crash Auto?Fix Auto.
yes, if you can shut off the key and remove it from the ignition and the car continues running....theres something wrong with the ignition switch.
However I fail to see how pulling the gas pedal backwards would stall the car out if the ignition is faulty, I'd inspect it for sure.
astrum
24
Nov 15, 2017 08:44 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
