wider tire that can be used with 18x10 wheels?275.285,or even295?
Old Jul 24, 2006 | 03:54 AM
13bmaniac's Avatar
well that just said it all what is the wider tire that can be used with a 18x10 wheels 275 285 or even 295 the fenders will not b a problem since the vertex ridge is on the way.
thanks
Old Jul 24, 2006 | 09:50 AM
Broken09's Avatar
I am becoming...
Many run 285/30/18 with very little problems
Old Jul 24, 2006 | 09:58 AM
vel525's Avatar
Woo Hoo, It Runs!!
That's what I run.
BTW, Nic it was nice finally meeting you. Not sure if you guys came back, but we were all probably gone by then (the whole ticket problem). Anyway, hopefully I'll see you around at other meets.
Victor
Old Jul 24, 2006 | 01:12 PM
13bmaniac's Avatar
what do you mean with running with very litle problems?
Old Jul 24, 2006 | 01:31 PM
Broken09's Avatar
I am becoming...
There is a chance if you're running that tire up front with no flares that you will rub. I had to ever so slightly roll my fenders running 265/35's.
-Nic
Good to meet you too Vic. We didn't head back after all. Just drove around for a while and called it a day. I'll make it out to another meet when there's more cruising involved and less sitting around. I get impatient too quickly haha.
Old Jul 24, 2006 | 05:19 PM
13bmaniac's Avatar
no im refering to the rear wheels i was cheking the nitto web site and says that with 10 inch wide wheels you can run from 275 to 305 tires so i gues that i can run a 285 or 295 easily .
in the front i will be putting 255 or 245 tires.
Old Jul 24, 2006 | 05:23 PM
rynberg's Avatar
It all depends on the aspect ratio. The "perfect" size tire for that wheel in FD tire diameters is 285/30. Some tire manufacturers may allow for a 295/30 18 tire for a 18x10.
Old Jul 24, 2006 | 09:44 PM
13bmaniac's Avatar
well im particulary interest in the nitto tires tey perform awesome i have the first nitto nt555 on mi civic and is by far the best tire ill have in my cars,so now i want the new series nt 555r or the r2 for a long lasting tire but yes i thing i will go with the 285 tires the 305 i thing will be a little of to much.
Old Jul 24, 2006 | 09:48 PM
jic's Avatar
jic
volk racing
sounds good..im running 265/40 in the rear
once those go out im gonna give 285/30 a shot
Old Jul 24, 2006 | 10:41 PM
13bmaniac's Avatar
i thing that if you ar not running wide body or flares you will have fender issues with the t
Old Jul 25, 2006 | 02:34 AM
whiteRE's Avatar
im running 18x10 with 275 with no problem
Old Jul 25, 2006 | 11:37 AM
13bmaniac's Avatar
well i see everybody is not running more than 285 tires for a 10 inch wheels,then i dont understand why you can put a 285 tire and a 305 in the same 10 inch wide tire
tire size tread depth dimension overal aproved rim
inches
285/35ZR18 97Y 5.0 11.22 9.5-(10.0)-11.0
305/35ZR18 101Y 5.0 12.40 10.0-(11.0)-12.0
nitto tire websie info
josef 91 vert
23
Sep 3, 2015 11:20 AM
