T04B & Mods....
Old Jul 22, 2006 | 10:23 PM
Phantomhp's Avatar
T04B & Mods....
Looking at getting a T04B with a .60A/R cold side,1.15 A/R Turbine and divided flange.
These are the mods I already have:
Walbro 255
Greddy 720 sec.
Ported Wastgate
Apexi AVC-R (Going for around 10-12 psi)
New fuel filter
3" Turbo back Motoria Exhaust
Rtek 1.7 ECU
Removed Split Air Valve , ACV and Sub Zero Assist
Mods Coming:
Wideband
Apex'i Neo
FMIC
The engine is still on stock ports as well. It's an 87 T2 S4
Also if possible could I just do pipes to fit on the top mount intercooler? I know it isn't recommended.
I would go standalone but just alittle high at the moment.
Don't plan on running extremely high boost levels. I am thinking right now between 12 to 14 if possible.
Looking at getting some 1600 cc injectors but would those be overkill?
Mike
Old Jul 23, 2006 | 12:39 PM
Nosferatu's Avatar
Sounds like a "V" trim T04B, a good "bang for the buck" turbo.I don't think trying to run 1600cc secondaries with a RTech1.7/SAFC combo would work real well.Staging them would be a bitch and decreasing the injector duty cycle with the SAFC increases the ignition timing because you are modifying the AFM signal.you might get it to work decently/safely with a 720/720cc or 720/850cc injector combo with something in the 10 psi boost range with that turbo.
Old Jul 23, 2006 | 02:56 PM
Juiceh's Avatar
Saiga-12 Power!
That 1.15 hotside may be a bit too large for stock ports. It sound to me like your goals would be best accomplished with a standalone. Don't waste your money with an apexi neo. You could sell the rtek and use the money from that and what you would have spent on the neo to buy a standalone. IIRC the TMIC is not very efficient over 12psi.
Old Jul 23, 2006 | 03:35 PM
Phantomhp's Avatar
Well, I think now I am going to go with the Rtek 2.0 vs the 1.7 and the Apexi Neo.
I just dont have the extra $1k to $1300 for a standalone.
Mike
Old Jul 23, 2006 | 03:43 PM
speed_monkey's Avatar
affen
Ever look into the megasquirt?
Old Jul 23, 2006 | 03:44 PM
Phantomhp's Avatar
Yeah, I wanted to get that plug and play mega that was in the group buy section but just missed it unfortunatly.
I PM'ed him and he said it might be a month or longer until the next batch. My car is down and I need it going so unsure if I can wait that long.
I still need a wideband either way but I noticed for the rtek 2.0 it has to be linear and the AEM Uego and LM-1 setups are both analog.
Mike
Old Jul 23, 2006 | 04:59 PM
jacobcartmill's Avatar
just dont care.
do not use the rtek7 ecu with a full turbo upgrade. you could get away with it with a hybrid turbo.
i had this exact same turbo you speak of on my streetported s5 TII. the 1.15 a/r ptrim turbine housing is going to be wayyyyyy too laggy on stock ports with 8.5:1 rotors.
i changed housings down to a .81 ptrim and it spools great. at 13psi i made 330whp with that turbo and the 1.15 a/r turbine housing and 360whp/305tq at 15psi with more tuning.. you are going to have to get a standalone.
and BTW you didnt mention which manifold or wastegate you plan on running
Old Jul 23, 2006 | 05:45 PM
Phantomhp's Avatar
Yeah,
Honestly I haven't 100% got all the parts in line for the full upgrade. Mainly just wanting to see if the engine and mods would support what I have so far as those parts are already bought except for the fuel control and widband.
If the engine won't handle it then I will probably stick with the ported wastgate S4 turbo and just up the boost on it with the AVC-R.
Mike
Old Jul 23, 2006 | 09:52 PM
gotrotors?'s Avatar
talk to error*, on this forum.
he builds megasquirt systems and they are just great, and fairly affordable. he would probly be able to ship it to you. wouldnt hurt to ask.
Old Jul 23, 2006 | 10:23 PM
Phantomhp's Avatar
I see what I can find on him.
But if I was to run the Rtek 2.0 which Wideband is good to use with that? The AEM and LM-1 both say they are analog while the Rtek site says must be Linear.
I have asked in the Rtek section but not much traffic there.
Thanks,
Mike
Old Jul 26, 2006 | 03:38 PM
Nosferatu's Avatar
Thanks,
Mike
Linear means straight Line as for as a graph is concerned.You want a WB that has a linear programmable analog output.The two you listed are exactly that.The Zeitronic WB is not a linear output and also doesn't have a programmable output as far as I can tell.
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
GreyBush
Sep 14, 2015 01:29 PM
GreyBush
Sep 12, 2015 02:23 AM
befarrer
Sep 4, 2015 08:26 PM
