HELP !!! Boost problem
Old Jul 22, 2006 | 12:30 PM
estevan62274's Avatar
#garageguybuild
Veteran: Air Force
I was at the track the other night and i my 4th run I was about half track and i heard sound of pressure escaping and a loss of power!! WTF !!! I was still able to drive the car, but it will not boost at all... It drives fine in vacume but once i try to push it into boost it wont... it sputters and wont. I checked my intercooer and pipes and connections... were else could the leak becomming from?? HELP !!!!
Old Jul 22, 2006 | 12:59 PM
classicauto's Avatar
Crash Auto?Fix Auto.
vac hoses perhaps....how carefully did you check the I/C hoses? make damn sure they're good because your problem IS a boost leak, no question.
Also check the elbow that bolts to the throttle body, I've seen them leak at the o-ring in there before.
Old Jul 22, 2006 | 05:15 PM
#garageguybuild
Veteran: Air Force
Well, i went around the car and sprayed some starting fluid on the intercooler, connector and vacume lines and the idle never changed!! I'm not finding a leak.
What other ways are there to check for vacume leaks???? need some help!!
Old Jul 22, 2006 | 08:25 PM
Sideways7's Avatar
He said BOOST leak not vaccuum. Check the places he told you to make sure they are tight.
Old Jul 22, 2006 | 08:30 PM
7dust's Avatar
Irregular Here
All of those places are under vacuum at idle.
Old Jul 22, 2006 | 08:45 PM
#garageguybuild
Veteran: Air Force
I'm going to get a cap for the turbo inlet and pressurize it to 10 psi. I hope i can find the leak that way!!
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
AXA
Sep 5, 2015 10:06 AM
gabescanlon
Sep 5, 2015 12:09 AM
