TPS Reading....help!!
Old Jul 20, 2006 | 06:15 PM
Carzy Driver's Avatar
Law Breaker
I'm adjusting my TPS cause idle is horrible. at throttle closed I get a reading of 0.88k ohm but at WOT I only get a reading of 1.12k ohm. I can't adjust my idle reading anymore cause the adjustment screw is all the way down. Bad TPS? I have extra one I going to try. BTW 87 TII. Thanks
Old Jul 20, 2006 | 06:17 PM
Law Breaker
BTW, I'm using this method cause I can even get the car to warm up:
http://fc3spro.com/TECH/HOWTO/TPS/tps.html
Old Jul 20, 2006 | 06:29 PM
spot_skater's Avatar
The Cause of Death
I'm pretty sure you should have like 4k OHMS at WOT. 4-6k or something like that. Sounds like your TPS is shot.
For my NA it's 1k ohm at idle, and 4-6k ohm at WOT. Swap it and see if the new one works.
Law Breaker
just tried another TPS and got the same results as before. Did my DMM wig out?
Old Jul 20, 2006 | 06:51 PM
Law Breaker
and I tried another TPS, same results. I think it's time to get a new DMM. I think I'll also try using checker lights aswell.
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
