i got flat spots on my tires from a hard brake i did
Old Jul 15, 2006 | 11:49 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
is there anything i can do to fix this or are the tires toast
Old Jul 16, 2006 | 01:09 AM
Black91n/a's Avatar
As long as you haven't gone to the cords, or completely wiped off the tread they should be fine, just keep an eye on them, as that spot will wear out faster. You may feel a vibration now at speeds due to the flat spots (if they're big), that's ok, but if it bothers you you should be able to get them re-balanced to take care of it.
Old Jul 16, 2006 | 04:09 AM
maxcooper's Avatar
WWFSMD
Re-balancing might help reduce the vibrations, but it won't cure it. There's a flat spot on the tire! It won't wear itself away from normal driving, either -- the flat spot will always be there.
I read a post once that some tire shops could shave a tire to reduce/eliminate the flat spot. I have never heard of anyone using such a service, and I doubt it would be a perfect solution, since it would be hard to make something that is soft and not round round again. But it certainly seems like it could help to some extent. If anyone has had a first-hand experience using such a service, I would like to hear about it.
Bottom line: you have to live with the flat spot until you replace the tires.
ABS is wonderful for avoiding flat spots. If your car has ABS and it stopped working, you might consider fixing it to avoid more flat spots in the future. My daily driver has no-longer-working ABS and I flat-spotted my last set of front tires when some idiot cut me off. Of course, I still haven't fixed the ABS.
-Max
Old Jul 17, 2006 | 10:58 PM
rexaholic's Avatar
just peel out for a lil bit every now n then to get it even. however, you'll have less thread. so you would have to decided wether you want some vibration on the car or les thread.
Old Jul 19, 2006 | 09:35 PM
MODERATOR
i went and bought some new ones its better because that vibrating was diving me nuts plus i figuered why kill my clutch,turbo,engine,diff...trying to make them even when all i am doing is bringing another problem
so the advice for today is next time dont brake to hard ...
Old Jul 19, 2006 | 10:07 PM
Mahjik's Avatar
Mr. Links
Better advice, learn Threshold Braking if you don't have ABS.
Old Jul 25, 2006 | 02:13 PM
dblboinger's Avatar
Just one question...how fast were you going to take that much tread off just from locking the brakes? Must be some really soft tires cause I've locked my brakes many times without damaging my tires. My recommendation...get different tires.
Old Jul 25, 2006 | 04:35 PM
maxcooper's Avatar
WWFSMD
Perhaps your frequent lock-ups are the result of your low-grip, hard tires.
-Max
Old Jul 27, 2006 | 01:13 AM
hsitko's Avatar
Archdandy
Flat spots dont go away. I recomend just continuing to do hard stops and hope that you hit the spots that arent flat until you make a round tire again.
Queppa
Nov 18, 2024 03:47 AM
astrum
24
Nov 15, 2017 08:44 AM
Microtech
30
Apr 23, 2016 06:37 PM
