West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Need help with my FB - Bay Area
Old Jul 7, 2006 | 10:48 PM
Dinnercoat's Avatar
Caramelldansen
Hey I live in the Bay Area, Fremont and am looking for someone to help me replace the clutch cylinders and possibly brake cylinder on my 12A FB. The car is immobile so you'd have to come with me but I can pay cash and/or feed you as my girlfriend is an excellent cook.
Inquire in reply or PM.
Old Jul 8, 2006 | 08:42 AM
Siraniko's Avatar
RX for fun
Originally Posted by MHopkins
I can pay cash and/or feed you my girlfriend.
hmmmm. hard choices there.
Old Jul 8, 2006 | 11:44 AM
BoostedRex's Avatar
NorCal 7's Co-founder
You back up in the Bay again Wacky?
Old Jul 8, 2006 | 04:49 PM
Icemark's Avatar
At most that is an hour job... what are you stuck on???
Old Jul 8, 2006 | 06:46 PM
Dinnercoat's Avatar
Caramelldansen
Simply removing the slave/release clutch cylinder. Real pain to get to, that coupled with my lack of forearm/hand strength. I may post in the 1st Gen Tech for any hits someone may have on how to go about doing it.
Also need to hit the yard again tomorrow, I found the waterpump fan spacer thing I need. But it looks like I'll need a pair of 10mm wrenches and some PB blaster.
Old Jul 9, 2006 | 02:17 AM
Siraniko's Avatar
RX for fun
in 2 weeks again. poor me.
Old Jul 9, 2006 | 02:20 AM
Siraniko's Avatar
RX for fun
replace the clutch slave, hoses and clutch master at the same time. So you dont have to worry about it.
PB blaster on the clutch fan spacer? You got to be kidding. Leave the belts in place, wedge a screwdriver on the bolts and loosen the bolts one at a time. The screwdriver will prevent it from spinning.
Old Jul 9, 2006 | 02:32 AM
Dinnercoat's Avatar
Caramelldansen
This is at the yard man. **** is rusted on good like.
Old Jul 9, 2006 | 01:56 PM
Smeagol's Avatar
The clutch master is kind of a pain, just make sure to get a 12mm deep socket. It makes getting in there much easier. When I changed mine out I was using regular sockets and trying to jam wrenches up in there. With the right tool it would've taken 5 min.
For the slave just use one of those u-joint adapters and a few extensions. Depends if you have all the stock stuff and the beehive oil cooler. If you have all that garbage it makes it harder to get to, heh.
Where is this car again?
Mike
Old Jul 13, 2006 | 05:50 PM
Dinnercoat's Avatar
Caramelldansen
Mike
Bay Area, Fremont. It can't travel either, due to this and other reasons. =/
Old Jul 13, 2006 | 05:54 PM
Siraniko's Avatar
RX for fun
hydraulic line to clutch slave cylinder: Be sure to break it loose before unbolting the 2 12mm bolts.
Old Jul 13, 2006 | 05:59 PM
Dinnercoat's Avatar
Caramelldansen
The rubber one or the metal one?
Old Jul 14, 2006 | 08:01 AM
Siraniko's Avatar
RX for fun
Rubber to slave cylinder. For hard to soft line, be sure to use 2 wrenches; whatever you have and 10mm flare wrench.
Old Jul 15, 2006 | 01:37 PM
SF@Rx7's Avatar
it's easy
where in bay area are you in?
Old Jul 15, 2006 | 03:28 PM
Dinnercoat's Avatar
Caramelldansen
Originally Posted by SF@Rx7
it's easy
Fremont.
Well I just got some extensions, deep wall sockets, and a universal joint socket thing so I'm thinking may be able to do it but still help would be great. ^^
scissorhands
Sep 16, 2015 01:25 PM
Tem120
Sep 7, 2015 09:53 AM
