KKK Stage 2 turbo
Old Feb 20, 2002 | 12:56 PM
EfinireFD3S's Avatar
KKK Stage 2 turbo
Hey guys
I just talked to Greg from SR Motorsports and ordered my KKK Stage2 turbo and it should be here in no time. I was debating between Apexi and T78 and just decided to go all out with KKK. I hope I made the right decision
Ernie : I guess there will be two people from MD with KKK turbo now or is there someone else with it ??
Old Feb 20, 2002 | 12:59 PM
1FAST7's Avatar
btw, ErineT what was your best time with the KKK stage 2 kit? and what about HP numbers? thanks
1FAST7
Old Feb 20, 2002 | 01:14 PM
Jason's Avatar
The one
For $1k cheaper the T-78 is going to give you the same HP figures. Im not saying the KKK kit isnt good, but its not worth the extra money.
Jason
Old Feb 20, 2002 | 01:23 PM
gustavocolberg's Avatar
I HAVE THE COMPLETE KKK KIT FROM SR MOTORSPORT(TURBO-ROAD RACING,MANIFOLD ,WASTEGATE,FUEL PUMP).I AM STILL IN THE PROCESS OF FINE TUNING MY CAR BUT I CAN TELL YOU IT IS A COMPLETE DIFFERENT BEAST.I DID A SOLO 1 LAST WEEK ONLY USING ONLY 11PSI OF BOOST AND I HAD TROUBLE KEEPING THE CAR IN THE TRACK.EXCELLENT KIT AND EVERYTHING WAS TRULY A BOLT ON.
Old Feb 20, 2002 | 03:50 PM
ErnieT's Avatar
Living life 9 seconds at a time
There is no way you can compare the T78 to my turbo. Not being an ***, just stating facts. I've driven in a T78 powered Rx7 and although it was nice, it didn't spool as fast as the KKK nor did it have the same top end. I won't ramble, but after I tune in the weeks to come and hit the drag circut w/ Demetrios, I'll be sure and post my results.
Old Feb 20, 2002 | 03:54 PM
Jason's Avatar
The one
Well I get full boost at 4100rpm and makes 432RWHP at 15lbs of boost. That is on a stock motor with a T-78. Take a ported motor and add another 30 RWHP. For the $1k it is not worth the extra money. H.P. numbers are going to be similar.
Jason
Old Feb 20, 2002 | 06:23 PM
DELTA_Rotary's Avatar
Bourbon King
I wouldnt complain if i had either.
PS gustavocolberg there is this key next to the "A" its called "caps lock" if you hit that button you wont make big letters.
Old Feb 21, 2002 | 01:51 PM
rotor_dee's Avatar
You would complain!!
I have had many different turbos. T-78 t-88 "Greddy" and many various garrett models. I can say ont thing that the KKK anf Garrett/turbonetics have over the apexi and greddy line. They are repairable. No matter what any one says if you break a shaft on a greddy turbo you are screwed. My T-88 went on a world tour. Japan Greddy, Thier quote was "we sell turbo's not repair them" then it went to turbonetics they can order a whole cartridge only but not individual parts for $1600. Then majestic said no problem sent it to them they said they can replace the compressor with a garrett one but can't get turbine wheels. So to make a long story short I have a T-88 in the garbage. My advice stick to a Garrett ot KKK they can be repaired at most shops within 24hours. Matter of fact I do my own repairs my self because the parts and documentation are so easy to get.
Old Feb 22, 2002 | 10:55 PM
boostedyellow7's Avatar
what are you doing with the computer system.are you ame or haltec or power fc or isee pms with labtop ive never heard off that one please explain. and how good of a deal did you get on the kit. we both have aboult the same amount off mods so am real curious to see what you think off the kit.
cristoDathird
28
May 30, 2019 08:47 PM
dkwasherexd
May 27, 2017 04:51 AM
sYnth.
Aug 19, 2015 06:27 PM
