How important is Loctite when working on the suspension?
Old Jul 4, 2006 | 05:16 PM
Wompa164's Avatar
Hi everyone,
I had a pretty easy question. How important is using Loctite on suspension bolts and nuts? I recently installed a set of Tein Flex coilovers and RE Toe Links + Trailing arms, and I didn't use any Loctite.
So, how important is it really? I made sure to torque everything to spec (I checked every bolt like 4 times just to be sure), but are my wheels going to fall off or something if I didn't use Loctite? Or is it just considered sort of an extra safeguard/precaution?
Should I go jack my car up right now and go Loctite everything, or am I safe to drive?
Thanks!
Old Jul 4, 2006 | 06:23 PM
Rx7@Rocketship.com's Avatar
You're safe. No LocTite needed.
Old Jul 4, 2006 | 08:40 PM
Black91n/a's Avatar
If anything you'll want anti-seize to keep the bolts and nuts from rusting to each other to the point where you can no longer remove them.
No lockTite? No problem!
astrum
24
Nov 15, 2017 08:44 AM
GrossPolluter
Aug 15, 2015 10:32 PM
