West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
new owner :O
Old Jul 1, 2006 | 02:33 PM
mothy's Avatar
new owner :O
hey guys, i just got a 1989 RX-7 GTUs manual, and im not really familiar with the rotary engine. i was wondering what should i do to it first. it needs a little body work. ill post pics soon :O
Old Jul 1, 2006 | 03:53 PM
socalrotor's Avatar
HAHAHA it has to be this car.https://www.rx7club.com/a-149/la-local-gtus-106-000-miles-ok-shape-551853/ If you need help hit me up, I am close to ya.
Old Jul 1, 2006 | 04:03 PM
FortyFiveD's Avatar
Devil in Training
If you just got it did you take it to a shop and or have a rotary person go with you to get it? Have someone give it a good once over so that you find any potential problems. Get them squared away then worry about what you want to do to the car. Good luck!
Old Jul 1, 2006 | 06:30 PM
mothy's Avatar
i already took it to a mechanic and stuff, everything checked out, it runs good other than it having the air coolant light come on and just beep at me (that might be a normal problem or something) but it drives great just the body needs some work. as far as making it go faster what should i put in first etc. can i turbo my car? if so what kind should i get cause i dont know jack **** about rotary engines lol. :O
Old Jul 1, 2006 | 06:55 PM
socalrotor's Avatar
Im in gardena. Is the car red? Is it the same car in the link?
Old Jul 1, 2006 | 07:22 PM
mothy's Avatar
yea its that car LOL, i saw it in the newspaper and i just bought it, she gave it to me for 1800, the mirror is glued on and **** which is fixable, everything else is really nice. i gotta go get a sound system in it cause the radio doesnt work, neither does the horn but its chill, for 100,000 miles it was a damn good deal :O
Old Jul 1, 2006 | 07:29 PM
socalrotor's Avatar
PM sent.......
Old Jul 2, 2006 | 09:14 AM
Kory_yahi's Avatar
Look ma'! I am spoolin'!
Sound system.... car running right?
Sound system... car running right...?
Which one would I choose... lol...
Old Jul 2, 2006 | 01:04 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Yeah, I'd make sure that it's running 100% right prior to spending money on a radio. Hell, my FC runs great and I still don't have a radio in it.
Old Jul 2, 2006 | 01:08 PM
FF_PwNed!!!'s Avatar
Ace
you wouldnt be able to hear it anyways not even with headphones
Old Jul 2, 2006 | 01:23 PM
socalrotor's Avatar
Me too, with my setup I would need a 1000 watts to hear anything.
Old Jul 2, 2006 | 02:55 PM
mothy's Avatar
well ofcourse i want my car running 100% right, i just got my oil changed and all that other ****. i noticed that my car smokes sometimes when im driving but rarely. and i have to give it gas almost 60% of the time when i start it up.
Old Jul 2, 2006 | 03:29 PM
AcidAngel7477's Avatar
We're All Fkd..
damn 60%? does that mean you have to gas it all the time on startup? that doesent sound right to me..maybe i just read it wrong..
:AA:
Old Jul 2, 2006 | 03:34 PM
socalrotor's Avatar
:AA:
you are right......TPS........
Old Jul 2, 2006 | 03:40 PM
FortyFiveD's Avatar
Devil in Training
That could be your injectors that starting problem. If you want to turbo your car you need to do the turbo engine swap when you do that it includes engine, trans, driveshaft, rear diff, ECU, and engine harness. I have heard that you can put a turbo on a n/a engine but it wont last. As for your first modifcation i would recommend suspension, next rims and tires. You shouldn't go to large with the rims 17 being the largest ( 18" rims are a little much for the n/a)
Old Jul 2, 2006 | 03:47 PM
mothy's Avatar
how much does the turbo engine swap cost, i need to start saving hahaha :P if this is another problem, when that air coolant light comes on my rpms go to like 3500, and then when i press the gas it doesnt do it anymore.
Old Jul 2, 2006 | 03:53 PM
RotaryEvolution's Avatar
Sharp Claws
i think you got ripped.
Old Jul 2, 2006 | 04:26 PM
BlackN/A's Avatar
Friends til the End
To understand the rotary better, check out www.rotaryengineillustrated.com They have some great animations that will explain how everything inside the engine works.
Old Jul 2, 2006 | 05:59 PM
GloryDays's Avatar
conservatively liberal
smoking? buy Hyper Lube's smoke fix. comes in a white bottle with red lettering. u should be able to find it at kragens or sum ****. it completely eliminates smoke... hense the name... ok i'll stop now.
Old Jul 3, 2006 | 02:21 AM
Sharp Claws
does this look like a ******* piston engine? shut your damn hood and sell your car!
Old Jul 3, 2006 | 01:39 PM
GloryDays's Avatar
dude it really works! recommended by Jeff at Rotary Power. He says hes been using it in his REPU for 3 years. I used to use it... The ***** really thick so i guess thats how it doesnt slip past bad oil control rings, so much, so no smoke. My car will be sold as soon as i fix teh size 15 boot dent in the back. Wanna trade? ....please
Old Jul 3, 2006 | 05:42 PM
mothy's Avatar
dude u guys arent much help. i want to make my car go faster u *****, karack how did i get ripped off, im not trying to sound like a ******* or anything i just want to know why and how, and 2nd off WTF aojFOAJSDGOADJGOADJGOAJDGFOJADGOj why does the add coolant light come on and beep at me for like 5 mins and then go away for the rest of the day, it only happens when i let it sit for more than like 6 hours or something. LAJGDSLJADGLJ/.
Old Jul 4, 2006 | 01:18 AM
GloryDays's Avatar
its because you need to add more coolant
no seriously though, u need more coolant. turn the car on, pull the throttle a little bit to get it flowing (u'll need help) and top it off. either that or youre losing coolant somewhere, or try cleaning the little sensor part off, just dont tear off the wire or else that annoying buzzer will never go off. im not exactly sure how it works, but try cleanin it cause you never know... have you overheated yet?
Old Jul 4, 2006 | 01:21 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
cool! they found a way to charge $10/qt for gear oil
that's the oldest trick in the book.
Old Jul 4, 2006 | 09:36 AM
FortyFiveD's Avatar
Devil in Training
The turbo swap will probably run you around $2500 for the engine and trans (minus labor) $800-1000 for the engine haarness (i think?) Uuummm i think the ecu will come with a front clip if you have to buy it seperate then maybe $40-100 (don't quote me on the price. I dont know about the driveshaft and rear diff. Hey dont let these guys get you down they just like ******* around no harm meant.
RX7-RR
Jun 10, 2018 11:40 AM
MRNICE
Sep 18, 2015 05:09 AM
