Mikuni Jetting
Old Jun 26, 2006 | 06:52 PM
RustyRotary's Avatar
Just soak it in 2-cycle
Mikuni Jetting
I've got a 44mm mikuni on an aggressive street port 12a that was designed to start making power around 5,000 rpms. I'm running a Comp-70 fuel pump. Anybody who has experience with a similar set-up, can you give me some suggestions as to what kind of jetting I should go with? Unfortunately, I don't have enough money to buy a bunch of jets, so I need too start off somewhere close. Thanks
Old Jun 27, 2006 | 07:55 AM
speedturn's Avatar
For Solex/Mikuni 44PHH two barrel side draft carb, used on street ported 12A with header and free flowing exhaust:
Venturi 39 mm
Main fuel jet #200
Air Jet #240
Idle Jet #62.5
Accel. Pump #90
Emulsion Tube OA
Note: you must have exactly 39mm venturies for the above jet recommendations to work. I used this setup in the early '90s on my street driven, street ported 12A. I still have a few Solex/Mikuni jets available for $5 each + shipping. I don't know what sizes I have on hand until I inventory them, so if you want them send me an email at
speedturn@hotmail.com and put the words "Mikuni Jets" in the subject line
Old Jun 28, 2006 | 02:34 PM
Hmm. That seems kinda lean. When I say aggressive SP, I mean like, as big as you can get
Old Jun 28, 2006 | 08:36 PM
speedturn's Avatar
Maybe I am wrong on the air jet size; maybe it was a smaller. My notes from 1991 are smudged on the air jet size.
What jets and venturies do you have right now? Have you even driven your car with the Mikuni PHH carb?
My street port engine back then was pretty strong. I still use a street port 12A for a daily driver now; only now I use a Weber 48 IDA downdraft carb.
Old Jun 29, 2006 | 12:13 AM
I ran it on my stockport, which I believe it was tuned for, but I have yet to run it on my current streetport. I'm not sure what the numbers are.
I've actually decided to just rebuild the carb with the current jets, test the A/F with a wideband, then choose jets accordingly.
Old Jul 3, 2006 | 05:54 PM
speedturn's Avatar
That is always a good plan. Every race engine is always a little different, and tuning with a good A/F ratio meter is the best way for good results.
dona1326cosprings7
Oct 29, 2015 06:47 AM
Jmolina0163
Oct 3, 2015 10:04 AM
