NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
Anyone interested?
Old Jun 21, 2006 | 08:00 PM
Question Anyone interested?
I have an 44 or 45mm ? Brand new side draft webber carb and intake manifold kit with foam air filters, fpr, fuel filter, carter fuel pump. All installed new and never run. I purchased from mazdaracing.com tuned for a sea level 12A no emmission. Paid $650 for the carb and intake kit which now cost $850-1000. Fuel has never flowed through any of these items.
For $700 You can take it all, plus I will throw in a 12A motor with oil meter blocked off (so you must pre-mix) and 5spd transmission, new oil pan gasket and shift bushing.
Add $200 and I will let you take the direct fire ignition setup that includes diagram, 12AL ($212) ignition, 2 blaster coils, 1 factory coil, 2 stock wires, 2 custom magnacore, plugs. Only used to turn over motor and run for 5 minutes when old niki carb was installed.
I am moving very soon and must sell. I am in western MA. If you have a truck, I can pull the motor and load on short notice.
Email me at bonjo2 "AT" charter.net, and I will find the box with the exact specs. Individual parts are avail as well to reasonable offers. I can post photos this weekend.
Old Jun 24, 2006 | 08:45 AM
12A Sale this weekend in Ludlow. I can hoist the motor and load it on your truck. Very clean!
Found the box. It's a Webber DCOE 45. As mentioned it's new. I found a similar kit for $650. So please consider the following new offer.
-Webber 45 DCOE Side Draft carb and Intake kit NEW for 12A motor tuned
to sea level at shop--never run, FPR, Carter ele fuel pump 65l, fuel
filter, foam air filters. As seen in photos... Kits cost between
$650-850 now. You pay $650 and I will throw in a 12A motor, and 5 Sp
Transmission with Shifter for Locost chassis. Oil Meter block plate
so you have to pre-mix. Will throw in a GIANT RX7 Oil Cooler and new
oil pan gasket and shoter alt belt to clear CMC hood. Your driveline
is nearly complete.
-Add direct fire setup (NO MSD IGNITION) Distributor, ignitor, 2
Blaster Coils, 1 Stock Coil, 2 stock wires, 2 Magnacore wires, and
wiring diagram for $50 All you'll need is a MSD 6A ingition and
you'll be set.
-ADD Rotary Header for Locost. Fits 12A motor. Uses Racing beat
flange, pipes, and merger. Wrapped. $40
-Locost Bullet style turbo muffler--no fiberglass to burn up $20
-Caterham 6 point Cam Lock Racing Harness from R500. Used 2 times,
and has been installed for about 4 years. $60 (less than the cam lock
alone) Fits locots PERFECT!!!!!
-Caterham R500 Fiberglass racing seat (1)--modified for those over
160lbs. USED. Very tight around ****, but fits car very easily, a
great match for racing harness above. $60 Take seat and harness for
$110!
-2 Diamond racing 13x7 wheels fwd offset 4x100mm NEW $40
-Small car battery. 3 years old, sat for 3 years. FREE.
-Aluminum floor, 1 side, from CMC. Too little overlap for my liking.
FREE
-CMC adjustable Panard Bar--Painted GOLD with racing beat sticker,
includes bushings.
WHY SELL. Moving to Wyoming. Must lighten load. Switching to a
1300cc Bike Motor--don't like the loud rotary rumble
Pass along to any rotory nut.
IN LUDLOW. AVAIL ALL WEEKEND.
Hit me at Bonjo2 "AT" charter "DOT" net
or in Western MA hint hint 695-6906
Old Jun 24, 2006 | 08:55 AM
The direct fire setup is from the Yaw power website. Fuel pump and FPR is also referenced on the Yaw site. Thanks for looking..
Old Jun 24, 2006 | 09:18 AM
http://webpages.charter.net/bonjo2/ Locost + Seven photos--see carb, motor etc..
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Cameron38
1st Gen General Discussion
Sep 19, 2015 11:45 PM
