Power FC Can the PFC control additional injectors?
Old Jun 19, 2006 | 10:50 AM
oorx7's Avatar
Custom or Nothing
Question Can the PFC control additional injectors?
As title says.
Old Jun 19, 2006 | 11:35 AM
sdminus's Avatar
Cant be bothered anymore
Yeah it can be used to fire 6 injectors. I think you have to piggy back a set and alter the settings for those injectors. ie 2 sets of 850cc secondaries or 2 sets of 550cc primaries
Scott
Old Jun 19, 2006 | 06:02 PM
RSXJOSH's Avatar
I was reading somewhere in the manual about using 4 injectors for the secondaries. You goota becarefull with what injectors you use because the PFC uses FET's to control the voltage to the injectors and if you pull to many watts 3Watts max you'll blow the FET's.
Old Jun 21, 2006 | 09:19 AM
DaleClark's Avatar
RX-7 Bad Ass
It would take a little bit of electronics thinkin' to do the job. Probably better to run 2 low impedance injectors with a resistor off one driver than 2 high impedance injectors.
Dale
Old Jun 21, 2006 | 10:50 AM
oorx7's Avatar
Custom or Nothing
Thanks for the reply's. I was just wondering if it is possible.
Th0m4s
Feb 26, 2019 02:04 AM
imitek
Aug 28, 2015 05:28 PM
Snook
Aug 15, 2015 08:18 AM
