Haltech E6X PWM Setup/Test?
Old Jun 18, 2006 | 10:24 PM
Carguy34's Avatar
E6X PWM Setup/Test?
Hey Fellas,
I just installed an e-fan and I am having issues getting it to turn on. I have the PWM1 wire (Violet/White) running to a relay that controls the fan. I never see 12 volts through that wire. I have tried to turn the fan on using low numbers to see if it'll work (65C on, 60C off, for example when water temp is 67C) and it has never turned on. I have checked the PWM1 enabled box too. If there somewhere else that I need to specify that I want to use PWM1? When I was looking through the help file, it mentioned a test that could be run to check the wiring. How do I run that test?
I have tested the relay by applying 12 volts where the PWM wire plugs in and the fan turns on and runs great, so I know the problem is the PWM wire. Should I just try a different channel (PWM2 for example) to see if that works? That was my next step but I ran out of time to try it today. Any help will be appeciated.
Thanks
Old Jun 19, 2006 | 12:28 AM
Derek10AE's Avatar
Shake-zula, the mic rulah
I could be wrong but from looking at the E6X wiring diagram PWM 1-4 are going to be grounds. Your grey/red ignition wire is your 12v common.
Old Jun 19, 2006 | 12:58 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
This has been covered a lot.... read this post: https://www.rx7club.com/showthread.p...ht=PWM+outputs
PWMs are sink to ground, ie. the negative side of the equation, so they go to the negative side of the relay.
Old Jun 19, 2006 | 06:36 PM
Carguy34's Avatar
That makes sense, thanks for the replies. I will try to get out there after work tonight to see if I can get it wired correctly.
Thanks again,
-Brandon
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
RX-Heven
Haltech Forum
Apr 27, 2004 09:04 AM
Bill B
Haltech Forum
May 2, 2002 06:53 AM
Red-Rx7
Haltech Forum
Nov 2, 2001 03:48 PM
