Sponsored by: CARiD
Are Vacuum Solenoids Interchangable
Old Jun 9, 2006 | 05:45 PM
carwreck's Avatar
Thumbs up Are Vacuum Solenoids Interchangable
Can anyone tell me if the vacuum solenoids on the ratsnest are interchangable and also if the turbo control solonoids are also the same. i have 2 sets of everything but neither is completely good so i would need to use part of both sets to make a good set....
let me know guys!!!
Old Jun 9, 2006 | 07:25 PM
salva's Avatar
Rotary Restorer
yes
Old Jun 9, 2006 | 08:04 PM
NeedFD's Avatar
R. R. R.
+1 yes
Old Jun 9, 2006 | 10:48 PM
HAILERS's Avatar
HAILERS
Yes and no. They are all the same, BUT if you look you'll see the filter is moved from one nipple to the other on some (two different configurations). The filter can be repositioned by pulling on it. It'll come off, then reinsall on the nipple it should be on.
In other words you can't swap the Relief solenoid with the EGR solenoid without moving the filter on the solenoid.
Go stare at the solenoids and you'll see what I'm talking about.
Old Jun 10, 2006 | 03:57 AM
carwreck's Avatar
so apart from the filter they are all internally the same spec?
thanks guys
Old Jun 10, 2006 | 10:13 AM
salva's Avatar
Rotary Restorer
The ones w/ the filter are also intechangeble, you just have to remove(carefully!) the filters.
Old Jun 10, 2006 | 05:54 PM
carwreck's Avatar
thanks guys....i will try to peace a complete ratsnest together!!
ls1swap
Jun 3, 2024 03:25 PM
Wicked93gs
42
Oct 7, 2015 11:58 PM
