just bought a t4 flange (4bolt) doesn't fit.
Old Jun 8, 2006 | 01:26 PM
hondahater's Avatar
spending too much money..
are all t4 flanges exactly the same? I just got a t4 4bolt flange from a guy off ebay and when I tried to align the holes non of them match up. I mean they are close and you all but they aren't anywhere near exact and would need to be drilled to get any sort of big enough bolts through the holes. Also the flange's outer diameter is smaller by like 1/4 of an inch than the one on the turbo? Whats that all about? Is this flange just crap? Thanks.
Old Jun 8, 2006 | 01:31 PM
hIGGI's Avatar
maybe you got T3 flange instead? :P
Old Jun 8, 2006 | 03:48 PM
RacerXtreme7's Avatar
NASA geek
There is two types of T4 flanges I have come accross (aside from divided and undivided). One odd ball does have a slight bolt hole difference and outer dimension differance. The inner turbine inlet is the same for the either. Theres also a "Euro T4" flange. Its basically a T3 footprint, but with T4 sized divided inlet. Generally those turbine that mate to the "Euro" spec run t4 turbine wheels, T4 inlet and scroll sizes, but with the af-mentioned t3 bolt pattern (some of the Master Power turbos on ebay come with this).
As for whats going with you, they either sent you a T3 flange, or perhaps you have one of those rare and weird slightly off t4 turbine housings and the flange they sent you was standard. Chances are they wouldn'e be sending you the odd-ball t4 flange because no one uses them.
~Mike....................
Old Jun 8, 2006 | 05:31 PM
hondahater's Avatar
ahhhhh ok, well I have the masterpower t61 however the .96 hotside is from the guy that sold it to me witch lives in new zealand so maybe that has something to do with it.........Damn, well I guess I'll just ask him to see if this is a special flange or what. thanks for the info racerXtreme7 and higgi.
Old Jun 9, 2006 | 06:15 PM
NeedFD's Avatar
R. R. R.
this site shows the dimensions of the housings including the flange pattern/spacing
http://turboneticsinc.com/turbo_dimensions.htm
Old Jun 11, 2006 | 02:06 AM
hondahater's Avatar
oh wow cool site, thanks man. Basically I talked to bobybeach and he said it wasn't any special flange. It's just a normal garrett backside. Anyways I talked to the guy that sold me this flange and he said I can take it back to him with a rubbing of my flange and he will make it for me. Sucks I gotta do this but at least he is willing to work with me. Thanks again needfd.
Old Jun 11, 2006 | 04:51 AM
NeedFD's Avatar
R. R. R.
no prob, glad to be able to help
Kruel13
24
Sep 16, 2015 09:08 AM
ncds_fc
Sep 10, 2015 03:52 AM
