how do i get the friggin idiot lights out
Old Feb 17, 2002 | 09:20 PM
DC350's Avatar
Rotor Head
yeah, i see the little clip at the back and i push it down and all that, how do i get em out! blah
Old Feb 17, 2002 | 09:26 PM
RETed's Avatar
Idiot lights? Warning cluster in the middle of the dash?
-Ted
Old Feb 17, 2002 | 09:28 PM
DC350's Avatar
Rotor Head
yeah, thats what i meant....oops but i got it, i was just being weak, and i can't see in the dark. But anyhoo what do i have to resauter in the little cluster in the middle of the dash? to get the clock and the other lights working. I got the little cluster right here, if you could let me know it would be great thanks!
~Evan
Old Feb 17, 2002 | 09:31 PM
billy's Avatar
i too would like to know how to get the clock working agean. if there is a way
thanks
billy
Old Feb 17, 2002 | 09:42 PM
RETed's Avatar
Concentrate on the pins that connect to the plug - these usually go bad first, and fixing them usually fixes the problems 90% of the time.
-Ted
Old Feb 17, 2002 | 09:46 PM
billy's Avatar
sounds good ill get wright on that and see if i can get that stupid things to work
thanks
billy
Old Feb 17, 2002 | 10:13 PM
DC350's Avatar
Rotor Head
how do i fix them? they look all...silver and fine
Old Feb 17, 2002 | 10:55 PM
DC350's Avatar
Rotor Head
Come on guys. i need some help here
Old Feb 18, 2002 | 12:38 AM
Keith's Avatar
Remove the old solder with either solder braid or a solder sucker. Then resolder.
Irv, Keith's dad
Old Feb 18, 2002 | 01:03 AM
Icemark's Avatar
You need to remove the trim panel (pulling back towards the rear and up at the same time), to access the two phillips screws.
To fix one, search.
But if you are unable to search (for what ever reason)...:
Remove the two above mentioned screws, unplug the idiot light assembly, remove the three screws across the back (noting the longest screw fits in the middle). Remove the rear access panel, and carefully pull out the circuit board making sure not to break or damage the thick circa 198x ribbon cables.
Where each and every terminal (where the plug was plugged in) is soldered in, carefully remove the old Mazda solder (without burning the circuit board) by heating it with a low wattage soldering iron, and then using either a solder sucker ($10 most electronics stores like radio shack) or solder braid. This is important, as just re-flowing the solder is only a half *** fix and worth just that much.
Once the solder has been removed, re-solder all those terminals back onto the board again taking care not to burn the board, and this time also avoid using too much solder and flowing into the neighboring terminals.
Re-assemble and reinstall. You may wish to plug in and test, before screwing it back into the dash and returning the trim panel to its correct location.
Old Feb 18, 2002 | 02:10 AM
DC350's Avatar
Rotor Head
whoa, thanks man, that was incredible i will do just that! thanks so much
Old Feb 18, 2002 | 03:13 AM
DC350's Avatar
Rotor Head
it smells burnt.....or is that normal
Old Feb 18, 2002 | 03:20 AM
DC350's Avatar
Rotor Head
and under the 1st whole board, with the lights lifted up, it doesn't look very good, there a few burnt out little silver contacts, and on the clock actual screen it looks burnt!
Old Feb 18, 2002 | 03:41 AM
DC350's Avatar
Rotor Head
well, so far i have taken it out, pulled it all to **** fucked up 3 bulbs and i dontknow where to solder, so i think i am just going to buy a new one
Old Feb 18, 2002 | 02:32 PM
DC350's Avatar
Rotor Head
yeah, i messed it up all real nice, gotta get another one! damnit
Old Feb 19, 2002 | 05:12 PM
Icemark's Avatar
yeah burnt traces are a bad thing. Only thing you can do is replace them or the whole assembly. I got a wiper switch not to long ago and it had burnt traces as well, but I replaced the burnt traces with insulated wire. (It was an 88 'vert switch and they are very hard to find)
Lucky the warning/idiot light assembly and clocks are pretty cheap at the wrecking yards, just make sure you match the year and model of the assembly to what you had before.
In 88 Mazda switched to a different type than what was found on the 86-87, and if you mix the two up you will need to replace the warning light trim panel as well. (as well as one from a 'vert doesn't have the hatch light, and one from a Turbo has a fan indicator, that would be useless on a NA, etc).
Old Feb 19, 2002 | 05:38 PM
DC350's Avatar
Rotor Head
I just baught an 86 gxl warning cluster, this should be okay right??
Old Feb 19, 2002 | 06:17 PM
Icemark's Avatar
Yeah, all the 86 ones will work on a 87 N/A
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
