Engine year
Old Jun 7, 2006 | 01:57 PM
slayerx7's Avatar
The nonspatial continuum
Engine year
Does anyone know how to tell the year of your engine by using only the motor??
I have an REW and the guy I got it from said he thought it was out of a '97 or '99 Rx7 I dont know for sure, and If I want to order an aftermarket computer, I should know... Are there any casting# codes that say on the motor anywhere???
Old Jun 7, 2006 | 02:07 PM
Sled Driver's Avatar
The Anti-Prius
The cores are interchangable. The electical harness will dictate the series year computer you use
Old Jun 7, 2006 | 05:10 PM
mono4lamar's Avatar
In the burnout box...
look on the front cover for the reman tag... most rx7's have a reman motor. the tag is blue and will be by the crank pulley on the front cover. hope this helps. i never knew about the harness being different
Old Jun 7, 2006 | 06:27 PM
slayerx7's Avatar
Actually I dont have the computer, or the (cradle? The part the computer chip attaches into) Hopefully that tag will be there, if its not, any other ideas? The wires that were leading to the harness were cut, when the motor was pulled... all 20some of them. thanks for your help
Old Jun 7, 2006 | 06:49 PM
rynberg's Avatar
It's simple. You buy a new '95 wiring harness and hook it up to the engine, discarding the existing wires connected to the engine. Then you use a stock/chipped ecu or a PFC for the US cars. Or if you are going Haltech or something, just remove the existing wires and make your new harness.
Old Jun 17, 2006 | 01:38 AM
slayerx7's Avatar
Is Haltech THE way to go?
Old Jun 17, 2006 | 01:44 AM
tt7hvn's Avatar
honestly, i bought a PFC before i ever learned about Haltech then somebody that loves Haltech totally, now i'm selling my PFC b/c if you look at it to get the same stuff out of the PFC it costs way more.....for a PC interface using the Datalogic that's an extra 375, then the electronic boost controller is another 400 and the PFC doens't even have a O2 wideband input...the Haltech has all of those except the electronic boost controller but that's only 80 bucks if you decide to get it.....in my opinion, Haltech is just a better deal and it seems to perform better considering you get full use of the ECU when you get it.
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
