Sponsored by: CARiD
stability parts for FC3S
Old Jun 6, 2006 | 01:34 AM
ROGUE FC's Avatar
Newbie
hey guys
im looking for FC3s series 5 pillow ball tension rods, Rear Camber Adjuster rods as well as Rear Toe Control Canceller and Tie Rod End and Spacer Kit
as well as adjustable links, and other adjustable stabilty parts
do these exist and if so where can i get em?
Old Jun 6, 2006 | 08:47 AM
DropTop7's Avatar
im an alignment tech at tirekingdome and i can see no way to adjust rear camber unless there is a kit, and i have heard of none that are made, there is however a toe adjustment. right now i do have a serious negative rear camber issue caused by very weak springs.
Old Jun 6, 2006 | 09:06 AM
Juiceh's Avatar
Saiga-12 Power!
http://www.mazdatrix.com/h6_86-92.htm
Rear camber adjusters, and rear toe eliminator bushings can be found here towards teh bottom of the page.
There is no toe adjustment just elimination bushings or buying a ton of new replacement parts from mazda for way too much to just replace the worn out stock ****. Eliminating the rear toe is the much better option.
Old Jun 24, 2006 | 10:56 AM
TehMonkay's Avatar
Back in the game
A company called KSP in Japan makes rear pillowball lower arms, and a company named URAS in Japan makes a steering angle spacer kit. SAaw it in the article with the gold FC in modified magazine.
Old Jun 24, 2006 | 11:07 AM
Natey's Avatar
I have a camber adjuster for sale
Here(Clicky)
Old Jun 29, 2006 | 12:19 AM
-Six-'s Avatar
duh, nevermind
FührerTüner
Time Slips and Dyno
38
Nov 8, 2018 04:13 PM
astrum
24
Nov 15, 2017 08:44 AM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
Wolf_
Aug 11, 2015 04:23 PM
