Going single: Necessary Gauges?
Old Jun 5, 2006 | 04:57 PM
Farhan's Avatar
RSPECT
Question Going single: Necessary Gauges?
Hey everyone,
I'm currently having a single turbo built for my car. I'm expecting it to take another 3-4 weeks until completion. In the meantime, I've just been buying up all the necessary parts I need.
Now I've been doing some searching and reading lately and it seems everyone has different suggestions when it comes to gauges that are necessary for a single turbo application. I really don't want to have any unnecessary gauges cluttering up my interior so I'm wondering which type gauges are ABSOLUTELY necessary? Any help or suggestions are welcome and thanks in advance.
Riz
Old Jun 5, 2006 | 05:44 PM
d1rx7's Avatar
oil/water temp, oil pressurer, and boost gauge, thats will be fine, mybe a air/fuel, you dont need the water temp or the oil pressurer gauge as the car already has them, but they do give a better reading.
Old Jun 5, 2006 | 05:55 PM
rynberg's Avatar
Boost, that's all that is absolutely necessary.
*water temp, should be displayed on the PFC Commander, although a separate gauge is nice
*oil temp, not necessary for street driving, but good to have for track use
*oil pressure, why, the stock one works fine with a good sender
*fuel pressure, good for setup tuning/troubleshooting but for daily use...not necessary
*EGT, good for tuning timing, not much good for anything else
*wideband AF, required for self tuning, nice to have for daily use, but....not necessary
Old Jun 5, 2006 | 07:08 PM
dubulup's Avatar
development
Thats all I have...and its not even on the pillar. Once the car is set-up and tuned...I don't even think it's a must, to monitor every WOT run.
*water temp, should be displayed on the PFC Commander, although a separate gauge is nice.
linearize the stock one and calibrate it so you know what the "clock" positions are.
*oil temp, not necessary for street driving, but good to have for track use.
I recommend a good oil cooling system (stock single won't cut it)...gauge should be used to find out where you currently are, then where your "single" friendly system put you and how the car reacts...no need for a constant monitor, unless tracking as rynberg stated
*oil pressure, why, the stock one works fine with a good sender.
+1
*fuel pressure, good for setup tuning/troubleshooting but for daily use...not necessary.
If you tune on the dyno, one on the FPR will do, tuning on the street...nice to know in the car. Tuning tool
*EGT, good for tuning timing, not much good for anything else.
good for aggressive timing tuning and if you plan to run AI (aux inj). Tuning tool
Tuning tool
Old Jun 6, 2006 | 12:07 AM
Click the link in my sig to see what I think is important
Old Jun 6, 2006 | 12:25 AM
r1dreamer's Avatar
boost and egt. make sure they are high quality. if you have the power fc. it has all the gauges you need.
Old Jun 6, 2006 | 12:51 AM
Farhan's Avatar
RSPECT
You think this upgrade is really necessary? I won't be running over 15 psi for the time being.
Anyways, since I'm not going to be tuning myself I think I'll stick with a boost gauge and probably water temp. I'm going to be running Defi D gauges so I don't think quality will be too big of an issue. Oh and I'm leaning toward purchasing a Microtech ECU rather than the Power FC.
Old Jun 6, 2006 | 03:00 AM
Sesshoumaru's Avatar
Tenseiga
I don't have one after market guage.
With an external wg your boost is rock solid with just a spring.
Stock coolant/oil pressure all i have to look at.
I don't need to second guess my components or my work.
If i do feel something is wrong i can alway just data log.
btw check out the haltech's. I've been very happy with the performance and price of them. Very easy to work with also.
Old Jun 6, 2006 | 07:38 AM
dubulup's Avatar
development
oil cooling is just as (if not more) important as water cooling...are you going to upgrade your radiator??
Old Jun 6, 2006 | 12:00 PM
Farhan's Avatar
RSPECT
I already have . It was actually one of the first things I ever did on the car and haven't had any real coolant issues ever. I'm currently running a Koyo Radiator.
What would you suggest as far as oil cooling? I've never really looked in to this modification because I figured it was more for people who autocross/track their cars extensively, both of which I don't really plan on doing. Thanks for the help.
Old Jun 6, 2006 | 12:46 PM
dubulup's Avatar
development
Since you don't really plan on doing either, a larger single cooler might be fine (19row). Dual oil coolers are ideal...if you plan on using a SMIC, a dual kit would help shed a lot of engine heat off to the sides instead on onto your intercooler (which can be dangerous for your air intake temperatures).
I'm far from an expert on oil cooling...just sharing my experience with a SMIC single turbo FD, with a stock single oil cooler system.
Old Jun 6, 2006 | 06:42 PM
Farhan's Avatar
RSPECT
Cool, I appreciate the help. I'll look into running a larger single oil cooler and probably do some more research on it. I actually already have a FMIC, and engine temps aren't really a big issue for me. I not only have mostly all the cooling mods done but I also have a vented aftermarket hood.
The1Sun
Sep 18, 2015 07:13 PM
kryan9
Sep 15, 2015 10:11 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
