Weird studering issue
Old Jun 3, 2006 | 07:46 PM
TurboTagTeam's Avatar
Broken FD
Al of a suden my car started to act up yesterday. It is studering when I take off in 1st gear. It starts to buck and allmost stalls,then it will then be fine all the way through the rest of the gear. But when stop at a light, when i push in the clutch, the revs drop. The car allmost stalls then returns to a 1000rpm idle. WTF????
Clifnotes-
1000rpm idle
bucking when aclerating out of 1st gear
Allmost stalls when stopping at light
BTW- my vacum is holding at 16psi so I know it can't be a vacum leak. And my map sensor is plugged in.
Old Jun 3, 2006 | 08:45 PM
Mazda99Nikon's Avatar
Gosh, I'm still a newb, so I won't claim to be the ultimate diagnostician, but a lot of fellows here would bet it's the small switch located just above your clutch pedal. There's a spring in there that gets stuck. You'll notice that's another switch above that. It's the lower of the two. Simple to replace, I'm told. And cheap too.
Do a search for idle and clutch. Should bring up lots of posts.
Old Jun 3, 2006 | 08:48 PM
BobfisH's Avatar
RX7 lover
the guy is right. get your head in the footwell, and follow the clutch pedal up till you see the little white button. Make sure it works ok.
and even if it looks like it works ok, that still doesnt mean it does. do the spring fix on it!
Narfle's Avatar
Rx7 Wagon
Any recent modifications?
Old Jun 3, 2006 | 11:10 PM
Broken FD
Actually the shortblock was replaced last week. But everything was running perfect untill yesterday.
I did drive the car about 40miles tonight. I have discovered that the studdering will go away once the car is fully warmed up. But the 1000rpm idle is there.
Also when I start the car cold, It idles at around 500-600rpm's.
I will check the clutch switch tommorow.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
