Sponsored by: CARiD
FC won't start...need help
Old May 30, 2006 | 12:20 AM
yangx's Avatar
i have a 86 fc. its current not working for a few weeks now. i've changed the alternator and battery to both brand new ones and its still not starting. a few weeks ago it did start but once it starts the car idles for about a few minutes perpfectly but then dies down afterward. i'll have to keep my foot on the gass pedal all the time inorder for it not to die down. i've been told it might be my TPS but i'm not really sure where and how to check it. anyone have an idea why my car might be dying out on me please let me know. also any tips on where and how i can check the TPS.
Old Jun 9, 2006 | 02:05 AM
nukeall's Avatar
You Need An Omh meter and it has to be at 1.00 ...dude buy the rx-7 book
Old Jun 9, 2006 | 03:45 AM
Carzy Driver's Avatar
Law Breaker
http://www.fc3spro.com/TECH/HOWTO/TPS/tps.html
Old Jun 9, 2006 | 11:07 PM
HAILERS's Avatar
HAILERS
You need to set the idle per the FSM. It includes a correctly set tps, but that is not your problem. The idle NEEDS to be set with the initial set coupler installled OR the BAC plug disconnected. Idle set to 750-800 rpm using the adjustment screw on top of the dynamic chamber along with the variable resistor if needed.
Prior to that you should use a timing light to set the timing with a fully HOT engine.
The BAC will HELP control the idle speed but only if the initial idle/timing has been set first.
squirrels
Sep 1, 2024 09:52 AM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
lnlreaper
Sep 27, 2015 09:59 AM
