compressor side trim help for a gt35r
Old May 28, 2006 | 09:24 AM
moonless's Avatar
Does any one know what trim/ar I would need for a garret gt35r. My tunner gave me specs to go with a .84 trim on the hot side and .70 on the cold side. Only problem is I can't find this trim for the cold side am looking to run 15 psi on the street and 21 psi at the track. Any help would be greatly appreciated.
Old May 28, 2006 | 10:15 AM
Poweraxel's Avatar
I suppose your talking about A/R sizing not "trim" ...for rotaries i suggest on not going with a small .84 turbine.... go with 1.00 or 1.06 minimum. Regarding the compressor side the .70 is standard. www.a-spec.com has the turbo you're looking for in-stock.
good luck
Old May 28, 2006 | 12:04 PM
Zero R's Avatar
Just in time to die
All you will need to know is GT35R. They only come in one trim 56 for compressor with a .70A/r, 84 for the turbine. A/r's I have available are .82, 1.06 T3, in T4 sizes are .84UD, .82D, 1.0D, 1.06D, 1.15D.
D=divided UD=undivided. I would go with the 1.0D it responds as good as the T3 and doesn't drop off up top like the T3's.
Old May 29, 2006 | 11:38 AM
moonless's Avatar
Thanks for the clairification on this.
C. Ludwig
Jan 30, 2019 06:31 AM
Clacor
Aug 14, 2015 09:17 AM
