Haltech please help!!! i need a map E8
Old May 27, 2006 | 07:32 PM
Gohan3rdrift's Avatar
Movie Star
i'm having my car tuned by steve kan in st.louis on july 2nd and need a map to get there.
i'd hate to trailer it back home after the tune.
so if any one has a map with this same setup..
please hook me up.
here's the setup:
13b-rew
haltech E8 v1.62
haltech wideband
ls1 coils
3 bar map sensor
850 primaries
1,600 secondaries
stock tps,coolant temp,air temp,cas sensors
t78
thanx in advance guys
tony
Old May 27, 2006 | 09:29 PM
Sesshoumaru's Avatar
Tenseiga
There is a map in the sticky that is pretty close
Old May 29, 2006 | 02:22 PM
Movie Star
yup
i tried it but it wont rev nor can i drive to a tuner on it.
it stalls right out when i try to drive it and it fouls the plugs instantly.
i was looking for a smoother map.
like if someone already had one tuned so i can at least take it to a tuner to compensate for my exact setup.
i just don't want to trailor/flatbed it.
i not dumb enough to boost it prior to tuning so no worries.
just take it easy till i get there.
Old May 29, 2006 | 11:35 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
If its too rich, select all the bars and lower it 5-10 % using the ALT-P shortcut key. Im pretty sure you will get it to idle better.
Old May 30, 2006 | 11:45 PM
Movie Star
Angry it does but
it does idle a little better but it wont start back up when i turn it off.
same goes when i decrease the fuel correction for the coolant temp and air temp.
i can get it to idle at like 11.6 :1 but it wont start back up afterwords.
i don't know what to do.
any other ideas guys?
Old May 30, 2006 | 11:51 PM
slo's Avatar
slo
registered user
Try turning off all the correction maps.
Old May 31, 2006 | 12:18 AM
Movie Star
tried it
same thing.
anything else?
Old May 31, 2006 | 11:43 AM
RETed's Avatar
RTFM?
-Ted
Old May 31, 2006 | 10:49 PM
Movie Star
Question what!!!??
what's rtfm?
ted. please enlighten me.
tony
Old May 31, 2006 | 11:26 PM
EFI Tech Wannabe
Keep leaning it out untill you get ideal mixtures, leave the correction maps alone and just keep lowering the bars. You never said what size injectors you are using so we're all guessing here without that little bit of info.
Also, what fuel pressure do you have it set to? usually these maps are fuel pressure specific, so, set it to around 40psi if its higher, if its lower than that, i would say you have big injectors. Either way post your injector size.
Old Jun 1, 2006 | 12:09 AM
slo's Avatar
slo
registered user
RTFM = read the ******* manual, Its the same thing I wanted to say but in all honesty I'm not that far ahead of you...
Old Jun 1, 2006 | 12:47 AM
Movie Star
injectors
850 primaries
1600 secondaries.
and the manual doesn't help with injector compensation so thanks for the help ted
your my hero.
just tryin to get positive input to help get my car to a professional tuner.
back to the issue.
once i decreased so much fuel .... it starts to run leaner but really rough and eventually dies.
i've recalabrated the o2 like 20 times now and always with the sensor outside of the exhaust.
Old Jun 1, 2006 | 12:52 AM
Movie Star
pressure
i forgot to mention my fuel pressure.
it's at a static 36 psi
Old Jun 1, 2006 | 12:53 AM
slo's Avatar
slo
registered user
I think you have other problems beyond simply being rich. Read all the recent posts that I have made regarding the timing, and verify that everything else is wired correctly. And if you still can't get it running good enough to get it to your tuner you could allways swap back to the stock injectors for the trip up there and swap them in when you get there. Of course the best option would be to trailer the car.
Old Jun 1, 2006 | 01:13 AM
Movie Star
do it
i checked timing at least 5 times and i've done everything according to "hitmans" way
i know timing is good cause it reads on halwin and using the timing light.
i'll try the 550's tommorow and see if i can drive using them,
but if u have any other ideas....please share.
thanks
Old Jun 1, 2006 | 04:30 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
hit me up on aim. i've got one that'll probably work.
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
