CD player install....which wire for ignition?
Old May 27, 2006 | 07:13 AM
DASUPACAT1's Avatar
I'm trying to install a cd deck into my s5. The previous owner who had the car had his player stolen. So the wires are hacked. No biggie since I will rewire the speakers with better wire. I got the ground hooked up, 12v constant, illumination, but I can't figure out where to tap into a igntion wire. Can anyody give me an idea what color wire or where to splice. I know I can hook up to the 12v constant but would rather not.
Old May 27, 2006 | 07:20 AM
jgrts20's Avatar
Who are you?
do you have a test light, or a bulb with 2 wires one for ground one for positive? use that and you will not have a problem.
Old May 27, 2006 | 07:28 AM
jgrts20's Avatar
Who are you?
ok went out to my car to look for you, im in the process of putting a new cd player in. My old one expired due to old age. The blue with white stripe wire is your ignition and the blue with red stripe is main power. buy a test light if you dont have one though very handy for every needs.
Old May 27, 2006 | 08:05 AM
DASUPACAT1's Avatar
I got so many wires that were cut when the radio was stolen. I'm doing process of elimination by pulling the old speakers and looking at what color wire they have. I figured out the rear speaker wires. Looks like there is more than 1 blue w/ white stripe. I guess i'll try and use my voltmeter.
I also checked my antenna which was ripped off. It is the non power, cuz I checked under the antenna mount. Is it possible to fit one of the rubber mast type. Looks like it won't fit cuz the hole on the wing is too small unless I take the wing off and mount it first.
Old May 27, 2006 | 08:25 AM
X-JaVeN-X's Avatar
Drive.
just take a multimeter...ground your black lead to the chassis...turn your ignition to accessory (so that your radio would normally turn on)...then take your postive lead and hit all the open wires...only 2 or 3 should show 12v (one is your constant, which you already have)....while showing 12v on one of the other leads...turn the ignition off....if the 12v drops to 0...you found accessory. That should take alot less time than pulling your door panels off and removing speakers to eliminate leads.
Old May 27, 2006 | 08:44 AM
DASUPACAT1's Avatar
I'll do that. Any ideas on the rubber antenna replacments? How do I get the spoiler off?
Old May 27, 2006 | 09:54 AM
jgrts20's Avatar
Who are you?
i replaced mine with a regular metal antenna, you might be able to see in this pic.
Attached Thumbnails CD player install....which wire for ignition?-picture-041.jpg
Old May 27, 2006 | 10:04 AM
DASUPACAT1's Avatar
I'd rather not go metal.
Old May 27, 2006 | 10:06 AM
jgrts20's Avatar
Who are you?
well just a suggestion doesnt look that bad and its just as good as any other. Goto the junkyard and get a OEM one then or get a roof mounted one like the VW's have.
Old May 27, 2006 | 10:15 AM
Aaron Cake's Avatar
Engine, Not Motor
Isn't this in the FAQ?
https://www.rx7club.com/showthread.p...72#post5131072
Now if you want an IGN source, then you will have to go to the black/white wire around the ignition switch.
Old May 27, 2006 | 11:15 AM
DASUPACAT1's Avatar
yeah i saw that.
i bought two types of rubber ant. to see which will fit.
Old May 27, 2006 | 11:23 AM
Icemark's Avatar
why wouldn't you just read the FAQ for FC sticky thread found at the top of this section and read all about the stereo power and speaker wires?
Old May 27, 2006 | 11:25 AM
Icemark's Avatar
Originally Posted by DASUPACAT1
yeah i saw that.
Rubber short antennas suck, you be bummed after putting one in at the reduced reception.
And next time read the FAQ for FC sticky thread found at the top of this the 2nd gen technical section. It has many of the commonly asked questions such s the stereo wires, that you started this thread with.
Old May 27, 2006 | 12:02 PM
X-JaVeN-X's Avatar
Drive.
yea that works too...haha, but now he knows how to do it in the future on a car that might not have a stereo faq
Old May 27, 2006 | 12:21 PM
'87 turbo II's Avatar
Sleeper but still slow
seeing as how most Rx-7s have a sunroof thiscould be a problem.
Old May 27, 2006 | 12:52 PM
DASUPACAT1's Avatar
I had a rubber mount on my fb. worked great.
astrum
Sep 7, 2015 11:41 PM
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
