Rewiring N/A fuel pump
Old May 26, 2006 | 10:22 AM
90WhiteVrt's Avatar
FC4ME
I've been researching and found that all i need to do to rewire the fuel pump is just running a 12 gauge wire and relay to the back and have the old power for the fuel pump engage the relay? I know very little about electronics, so i was wondering if anyone knew of a n/a writeup or could explain this in more detail. Thanks
Old May 26, 2006 | 10:23 AM
My5ABaby's Avatar
Rotaries confuse me
Same wiring, different pump. Don't see why it'd be different.
Old May 26, 2006 | 10:35 AM
90WhiteVrt's Avatar
FC4ME
^Do you know of any N/A writeups?
Old May 26, 2006 | 11:19 AM
My5ABaby's Avatar
Rotaries confuse me
I would assume it's the same as the TII write-up. The pumps hook up exactly the same.
Old May 26, 2006 | 11:21 AM
90WhiteVrt's Avatar
FC4ME
^The TII writeup is similar but different because the voltage drops to 9V at idle on the turbo's and changes when gas is applied. The NA's run at a constant voltage.
Old May 26, 2006 | 11:29 AM
My5ABaby's Avatar
Rotaries confuse me
You should still use the same writeup.
S5 N/A's have the same 2 speed fuel pump as the S4/S5 turbo's.
http://www.1300cc.com/howto/how2/rewire.htm
For S4 purposes (if someone searches for this):
Originally Posted by NZConvertible
To do this on S4 NA, all you do is run a new fused power wire from the battery directly to the fuel pump via a normal 30A relay, and switch the relay with the original fuel pump wiring. Very simple and easy.
Old May 26, 2006 | 08:30 PM
NZConvertible's Avatar
I'm a boost creep...
Well that saved me a job.
