Idle and starting problems
Old Feb 16, 2002 | 09:59 AM
rhubarb's Avatar
I just got a 90 Convertible, 5 speed with 140K miles.
When cold it starts and runs fine. Stays at 2000 RPM longer than my 88's used to (I've had 3 of them) but thats OK.
If I shut it down for 20-30 minutes, its hard to start and the idle will drift between 500-800 RPM with the clutch in.
Last time I drove it, I pulled out of the parking lot and when i went into second gear, the engine wound rev up and down between 1000 and 2000 RPM no matter how much I pushed the gas pedal. With the car in gear it was jerking around horribly.
I shut the engine off, waited, started it again, engine revved normally once, then started the 1000-2000 pulsing again. After a few restarts, it finally ran normally.
I am thinking TPS is the first place to look ... but I never had to make any adjustments on my other cars so I am not sure what is involved.
Any other ideas as to what this problem might be?
THanks
Old Feb 16, 2002 | 10:42 AM
Erik's Avatar
Best of both worlds
my guess is that the TPS is good place to start like you said. since its a 90 you can check the codes ( www.1300cc.com ) has a nice tutorial on how to do that. is there any rough acceleration?
Old Feb 16, 2002 | 11:59 AM
rhubarb's Avatar
Thanks, I'll take a look.
It does not run rough other than idle. It pulls very strong.
Kyo
Apr 13, 2019 09:24 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
85TIIDEVIL
Aug 25, 2015 12:09 AM
