Solvent "bath" for secondaries?
Old May 26, 2006 | 02:40 AM
C-Murder's Avatar
Whip it good
I've narrowed down a high rpm hesitation to sticky secondary injectors, and I'm a little bit lazy to take them to a place to get them cleaned (No where nearby will clean them); and I was wondering if anyone has tried letting them soak in a solvent bath for a while and acheived any sort of results. If so, what did you soak them in, and what was the procedure?
Old May 26, 2006 | 01:37 PM
C-Murder's Avatar
Whip it good
any objections to soaking them in Carb Cleaner? injector cleaner?
Old May 26, 2006 | 02:03 PM
1987_Gxl's Avatar
ALLyourRX7areBELONGtoUS
not sure if its safe for the o-rings... I'd get them professionally cleaned... 10-15 bucks per injector, and they even get fancy flow testing and sonic cleaning.... don't half-*** it, do it right or don't do it at all
Old May 26, 2006 | 02:05 PM
oakback's Avatar
meh
Originally Posted by 1987_Gxl
not sure if its safe for the o-rings... I'd get them professionally cleaned... 10-15 bucks, and they even get fancy flow testing and sonic cleaning.... don't half-*** it, do it right or don't do it at all
Yes, and just get all 4 done while you're at it. It might make a noticeable difference, and peace of mind is a good thing.
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
eplusz
15
Oct 7, 2015 04:04 PM
