In cabin mbc
Old May 24, 2006 | 10:03 PM
my-sons rx7's Avatar
In cabin mbc
I search but could not find. How is the best way to run the vaccum hose from the turbo wastgate to inside the cabin to the boost controller. Is there any holds in the fire wall i can go through, Becouse i don't see any. Any easy way or good Ideas how to run it. Any body done this please tell me how you did it . Thanks Tony
Old May 25, 2006 | 01:07 AM
Wankel7's Avatar
Haven't we ALL heard this
If you look where the AC drain is in the fire wall that could easiley be opened up. You can get a drill on the back side.
James
Old May 25, 2006 | 01:21 AM
DC350's Avatar
Rotor Head
With so much vacumn line running everywhere it will make your boost controller not as effective... Correct me if i am wrong
Old May 25, 2006 | 01:52 AM
Boostmaniac's Avatar
Depends on the boost controller. Some of the fuzzy logic ones will anticipate the slow response and start acting early. But I don't think the difference would be to bad between that and an MBC in terms of response.
Old May 25, 2006 | 01:56 AM
Funkspectrum's Avatar
I think there's a writeup on this on the MR2 forums....
MR2OC.com, Twosrus.com or something like that...
Old May 25, 2006 | 05:24 AM
Turbonut's Avatar
Take a look at the Hallman remote MBC. Great product, and the MBC is adjusted by a cable so that the hose is kept short. I believe I paid around $140 for mine.
Old May 25, 2006 | 06:43 AM
SureShot's Avatar
Seduced by the DARK SIDE
Another option: T in a bypass circuit with a solenoid.
Switched off, it bypasses the MBC & holds boost to 5 PSI.
Switched on, it closes the bypass & uses the MBC.
It's simple, reliable, & runs on one wire.
$35 including the MBC.
Old May 25, 2006 | 08:06 AM
BTW i have a 87 t2 and the mbc is a turbo-smart gated.
Old May 25, 2006 | 08:37 AM
classicauto's Avatar
Crash Auto?Fix Auto.
pfffffffftt response - shresponse, plumb the thing in there and be done with it.
I beleive your best bet would be beside one of the A/C evaporator lines as mentioned, you can access the back side of the lowest one without taking anything apart.
Hey that isone sweet setup you've got there sureshot!! beats the heck outta my slick old school RB in-cabin......I like the fact that you can go right back to stock boost without messing with the MBC settings.
Old May 25, 2006 | 07:32 PM
sureshot can you use this setup on a 87 t2 s4 or is it only for a s5
were is the solenoid air valve on a 87
the console switch is that just an on and off switch you by at raido shack
Old May 26, 2006 | 07:32 AM
Old May 26, 2006 | 07:40 AM
88rxn/a's Avatar
tom port.. AKA streetport
ran right beside the A/C holes...short lines...works well
Old May 26, 2006 | 10:52 AM
SureShot's Avatar
It will work with any turbo vehicle.
When I did the vac simplify & emmissions removal, I kept the old solenoids.
When I hooked up the MBC, I just used one of them & capped its vent.
All my modification wiring is passed through the former ABS harness hole.
The switch is a hooded safety switch from a parts store.
The label was made on a Brother label maker.
Old May 26, 2006 | 01:13 PM
88rxn/a's Avatar
sureshot!!! thats freakin awesome!!!
maybe i could use 2 boost controllers? run one right after solenoid..
that way i could run 10 LBS. all day and track day...throw the switch and hit 14 or 15???
of course it wouldnt be on a stock turbo!
Shainiac
Jul 17, 2019 02:20 PM
