TurboII won't start after running fine...it's not flooded.
Old May 23, 2006 | 08:38 PM
Rice_cooker's Avatar
Okay so I have a friends TurboII here.
It has been driven around for about a month now since he picked it
up. It's stock, just has a Racing beat exhaust and FCD.
well after letting it sit at my house for about 3 days we go to
drive it and it fires right up no problem. It idles for about a
minute then dies. It fires back up on command and I drie it out from
my garage.
Then it dies a minute later when we get it to the street. It takes a
second to fire up this time but it fires and we drive to the corner
of the block and it dies, and now it won't start anymore.
I pull out the plugs and they are in desperate need of beeing
replaced.
So I put new plugs in and deflood the motor. It sounds as though its
making good enough compression, I try starting it while playing with
the fuel fusible link under the hood to keep it from flooding again.
Well nothing.
I pull the wires and test for spark and there is nothing.
No spark, and this is on a new and fully charged battery also.
What's going on here???
Any help?!
Thanks.
Old May 23, 2006 | 09:52 PM
bump
Old May 24, 2006 | 02:23 AM
anyone?
Old May 24, 2006 | 03:27 AM
AUGieDogie's Avatar
Loose fuse/wire??? I some how blew my engine fuse and it took a while to figure it out. With that fuse out it would crank fine but got know spark. Just something to check.
Old May 24, 2006 | 08:40 AM
Dcrasta's Avatar
I had a wire in the main harness (near the alternator) go bad. After i redid my engine grounds it started. Check all your ground wires. If the ECU not getting a CAS pulse it wont fire either.
No spark is a sign the ECU isnt seeing a pulse.
Old May 24, 2006 | 04:34 PM
Where is that fuse located??
Old May 24, 2006 | 04:36 PM
But it was running fine, it just suddenly died, then I was able to restart it. Then it died again and won't start.
Old May 26, 2006 | 12:16 PM
bump
alphawolff
Nov 17, 2015 05:57 PM
PhillyFC
Aug 21, 2015 06:36 PM
Im faster
Aug 19, 2015 02:57 PM
86glxNA
Aug 18, 2015 03:33 PM
