Eibach's with tokico adjustable shocks/struts w/ stock sway bar?
Old May 23, 2006 | 06:58 PM
rotor vs. piston's Avatar
Function > Form
Is anyone running this set up?
On my gutted FB I have tokico blues, ST springs, with ST swaybars and I'd say it's a bit to stiff for the daily grind here in the DC/Balto area.
I'm getting another FB for the daily grind and it has tokico blues, racing beat springs, with stock sway bars... I haven't driven the car yet but the ST and RB springs are pretty close in rate with the RB's being stiffer IIRC so I'm not expecting more compfort.
I have a set of Eibach's (pro-kit) that I think would be good with a set of tokico adjustable shocks for the daily drive but I'd like to see if anyone has run these together and what their opinion is.
I also have a set of Monro replacement shocks for the FB that I thought about using with the Eibachs.
Old May 23, 2006 | 07:09 PM
RacerX7fb's Avatar
paradox
I have been using Eibach ProKit springs with Tokico Illuminas. Worked well for me on the track at Mazfest just a few days ago.
Suspension Technique springs have the softest spring rate amongst the three you mentioned, and if you think that's too stiff then perhaps stock springs and 60 series tires will suit your daily driving needs.
Old May 23, 2006 | 07:29 PM
MWMburton's Avatar
i have the prokit and the illuminas all around and i've got to say they're pretty amazing. super stiff if u want it and handles a hell of a lot better than stock.
Old May 23, 2006 | 07:34 PM
Tranquil's Avatar
Wankle Waffles
Many sports cars have really stiff suspensions. Some wives complain about it, some men have certain "ailments" that pain them. Either way, there is a new SPORTY solution to the problem.
Old May 23, 2006 | 08:38 PM
trochoid's Avatar
Old Fart Young at Heart
I have the Eibach prokit, ST bars F&R, Illuminas and a full poly bushing swap. Handles like a skateboard and it is stiff. The only part that will soften the suspension up is installing oem springs, then adjusting the Illuminas to suit.
Unfortunately the donut won't do me any good, my problems are higher up, and no, it's not above the sholders. lol.
Old May 23, 2006 | 09:40 PM
Function > Form
LOL!!! I deserve this I guess.
I from these comments I'm going to see how the eibach and monro combonation works with the full poly bushing swap.
I have to admit, my Scooby does spoil me a little.
Old May 23, 2006 | 10:04 PM
trochoid's Avatar
Monroe shocks, not, save you money and get the Tokiko HPs at least. The Monroes will only make the ride harsher.
Old May 23, 2006 | 10:43 PM
Function > Form
Already have the shocks from another car... so it would just be time. I don't have tokico illumina's but do want a set anyway so hell how many combos are possible with the following?
Srings............................................ Shocks/Struts...............................Swaybars
Racing Beat...................................Tokico Blue's (HP)..........................ST
Suspension Techniques.................Tokico Illumina..............................Stock
Eibach............................................ Monro (because I have 'em).........Stock w/o front
Stock, I'd need a set of stockers
matty
Jan 18, 2020 10:39 AM
82streetracer
Aug 23, 2015 09:28 AM
need RX7
11
Aug 19, 2015 08:27 AM
