single to 4pot brakes
Old May 22, 2006 | 10:01 PM
wiL87's Avatar
Can anyone help me do or find a writeup on how to do a complete swap from single to 4pot brakes? What to change, how tos and stuff? I did do a search. Maybe I didn't type in the correct words but if someone does find it, the link would be fine. no need for flaming. I AM a noob =\
Old May 22, 2006 | 10:18 PM
FirstRotaryExp's Avatar
The Brap is Back
I believe weve covered this topic fairly recently here in teh 2nd gen forum, past few days I believe. There may be a thread in teh faq, though its a straightforward process.
Remove old single pot fronts, old brakline, old dustshield. Reinstall larger dustshield from 4pot donor car, install rotor, install 4pot caliper, use 4pot cailpurs lines. thers more but my helping ran out when it hit 11....been up on 3 hours sleep since 6am
Old May 23, 2006 | 12:51 AM
Rotary_Knight's Avatar
you don't really need the dust shield. I used th same one. All I swapped out was the calipers, pads, and the brake lines to the calipers. It's probly a good idea to resurface your rotors cause the pads on the 4pots are bigger. It's pretty much straight foward, and also get some brake fluid and a friend cause you'll need to bleed the brakes.
Old May 25, 2006 | 11:07 PM
wiL87's Avatar
bump? =) anyone find a thread on step by step? or with some pictures atleast =D
Old May 25, 2006 | 11:10 PM
trainwreck517's Avatar
Rx-hippie
Is this a S4 4 lug? Or S5 Five lug?
If its a S5 five lug with single piston, yuo only need the caliper and new pads.. you use the same rotors and brake lines. Just swap out the caliper with the 4 pot, bleed the lines, and your done.
Old May 26, 2006 | 11:04 PM
wiL87's Avatar
It's an S5 5lug. Don't I need the 4pot brake booster and master cylinder too?
Old May 26, 2006 | 11:23 PM
misterstyx69's Avatar
Retired Moderator, RIP
I just did the Swap from 4-5 Lug..with Brake Conversion.the whole 9 yards...But,I did not change the Master or Flex lines.My "new" system works just Fine...single piston in Rear,four Piston up front.Vented Rotors all the way around.It will bring the car back to Zero pretty Quickly..no comparision.It was worth the Swap.(car is a 86 ..with a 13b N/A..if that is any help at all.)
Old May 26, 2006 | 11:58 PM
Rx-hippie
No, Stock S5 will work fine... I think they might be the same?
Old May 27, 2006 | 12:11 AM
86gxl_fc's Avatar
yup its all straight forward. on the S4 the 4lug rotor is thinner than the 5 lugs
i decided to rebuild my calipers while i was at it.
i swapped in the whole assembly, much easier for me i just took the three supporting bols in the rear and the large nut that holds onto the shaft.
in the front it was just the tie-rod en crown nut,
the ball joint screw on the bottom half of the rotor,
and the two bolts that screw the the strut.
pretty simply.
Old May 27, 2006 | 01:36 AM
wiL87's Avatar
wait, so for my S5 5lug, i DON"T need the master cylinder and brake booster off one with 4pot calipers to do the swap??
Old May 27, 2006 | 02:05 AM
Rx-hippie
Correct.
Old May 28, 2006 | 08:30 PM
wiL87's Avatar
Alright. Thanks a lot guys. If I do decide to replace it (because it's hella rusted), do I just replace it? or is there any thing I have to do prior to removing or installing it?
Old May 28, 2006 | 08:40 PM
robtechfabrications's Avatar
needs an FD
i'm going to be doing this swap really soon (in the next week or 2) and since this topic comes up all the time i'll take a ton of pictures and do a good writeup on it. so one of the mods can FAQ it or something.
Old May 29, 2006 | 02:25 AM
wiL87's Avatar
Cool Rob, Make sure to keep us updated. Are you upgrading to 4pot from single on a 5lug also?
Tem120
Sep 7, 2015 09:53 AM
Nosferatu
Sep 5, 2015 02:13 PM
Frisky Arab
Sep 4, 2015 06:17 PM
