Is it possible that leading coil work 1/2?
Old May 22, 2006 | 05:04 PM
hugo20's Avatar
I have recently installed haltech e6x in the car, everything was working fine but last week the alternator died. I had it repaired but now it is the leading coil that seam to work only 1/2.
Rear rotor fire and front does not. (It was tested with timinglight)
Two differant leading coil was tested, with the exact same problem.
I tryed to run a wire from the battery negative to the coil metal fixture. Still the same problem.
What I don't understand is that the leading coil signal is given to the pink wire by the haltech. How the hell that the coil could only work halfway? Could it be sparkplug wire problem? Cause I know they are getting old, it hurt when I touch them... (I have ordered new one, but I need to know if it could be something else).
MoTeC
Sep 10, 2015 07:58 PM
befarrer
Aug 14, 2015 04:18 PM
Wolf_
Aug 11, 2015 04:23 PM
